Coffee break not lasting full 3 minutes
What doesn’t make sense is being on a bot ride with 80 other people and after a minute, being left on the side of the road.
Then two days later, riding an organized group ride with about 60 people. In the middle of a group, I come back and I’m sitting on the side of the road again.
Both with time still remaining on the clock.
But I have tested this on a couple of other rides and it work. So I can’t figure out what the problem is.
Talking with Zwift support they are aware of an issue.
Also if you are not on the same route as the rider you’re attached to, they make a turn deviating from your route, you stop because you’re not attached any more.
Sure it does.
It’s the same exact scenario; if you get attached to someone who quits, stops, leaves, joins another ride… takes a turn as Paul just mentioned, etc. etc. etc.
This is just the core function of Coffee Break. It’s been like this since day of release.
It just needs to be coded to lock you onto a beacon, and if no beacon is present, disable.
Yeah, that makes sense
Both times mine failed. I was either on a bot ride with a group or I was in an organized closed group ride.
That’s a thought I had yesterday since the first time I was actually with one of the training bot :robot: . If you’re with one of those, why doesn’t it just lock you in with the bot leader, and if you’re with an organized group ride like I was, why doesn’t it just lock you the yellow beacon?
One of the reasons I’m trying to make sure this is working correctly. Is that last year? I did a couple of centuries on Zwift with a group of people and the coffee break worked good for swapping bottles, etc. when you’re with a group for 5,6,7 hours
In the past, we just set mileage stops at say mile 30, 50, 70 when doing a century and everyone just powered down to the side of the road. The coffee break really made it a lot better.
Last thing, I am in contact with someone from Zwift support. And they acknowledge that they are aware of an issue. And are working on it.
This is the reason I posted on the forum in the first place. To see if anybody else was seeing anything funny. Not trying to stir the pot.
Okay, this makes sense for my issue as the route I was on had very few riders and they were pretty spread out.
