Hello, has anyone used those chinese ANT+ USB sticks from aliexpress? I want to buy one (http://www.aliexpress.com/item/USB-ANT-Stick-for-Garmin-Forerunner-310XT-405-405CX-410-610-910-011-02209-00/32487649573.html?ws_ab_test=searchweb201556_2_79_78_77_80,searchweb201644_5,searchweb201560_6) and pair it with Garmin speed/cadence sensor but I can’t find any information if it will work. If there is someone who used it please tell me.
I bought one that looks just like that off of ebay (seller located in Hong Kong) and it works with the Garmin GSC-10 along with the Garmin HRM that I have. Even though the description doesn’t mention the GSC-10 being compatible I figured I’m only out $12 bucks but it does work.
Thanks for fast reply, that’s what I wanted to read.
We have a few of those at ZwiftHQ and the antenna is much worse than the USB-M garmin stick, but if you don’t have a lot of interference in your training area and use a usb extension it’ll probably work fine.
Thanks for the additional information Jon. I had my laptop right next to me when I tested it out last night for all of 8 minutes. Good to know that if I do run into problems then a usb extension is a quick fix.
I bought one from e-bay and have a 6 ft USB extension. I have it mounted close to the BB and it has been flawless with a Tacx Vortex, Mio HR wriststrap and CycleOps Powertap. It also worked with my GCS-10 but I stopped using the GCS-10 for obvious reasons.
