How do you use the mobile app to change direction (go left or right etc) at a junction. I find using the Apple TV remote too fiddly. I cannot see any option when using the app
The arrows to change direction will appear once you are close to the intersection.
Hi If you have your mobile app connected to Zwift while riding you will see the map screen, at the bottom there should be buttons. the arrows only appear at the turns.
Thats what I thought, none show on mine. I will uninstall and do a fresh download
Is the Zwift Companion App connected to the Zwift App on your ATV?
Yes through Apple TV. Always used a laptop until recently so never used app before. Everything else seems to work, ride ons etc etc
There is an issue where some turns are not working in Titans Grove.
