Would love some friendlier behavior to how XP is rewarded with workouts.
If a workout has repeated intervals (e.g, work interval, rest interval, repeated say 6X), award XP as each interval is completed, NOT as an entire block. It’s frustrating to stop for a bathroom break or have a trainer connection issue in the middle of 45-min repeat session and get 0 XP from it.
Similar to above, it’s ridiculous that stopping at all (bathroom, connectivity problems, etc) causes that interval to fail. This has happened to me during long 20-60 minute intervals where I need to pause to use the bathroom but otherwise successfully complete the workout… 0 XP.
I don’t agree with your point #2. If you pause the workout and come back you have to get your power in the correct range (use the companion app to see watts) and then un- pause then you wont loose stars.
I would also suggest breaking long segments into smaller blocks, because you never know when you need to stop.
We’ll have to agree to disagree. What would be more helpful is if the pass/fail “rules” for an interval were relative to the interval length. Having 10-20 seconds of getting your power back up after a stop shouldn’t fail a 15+ min interval. And yes, you can pause before you stop pedaling, get your power back up and then unpause… but again, it seems unnecessarily strict. If I have a connection dropout, you can’t do that, or if I hope off for the bathroom and forget that pause. TrainerRoad handles this perfectly with auto-pause.
What is the downside in relaxing those rules a bit? A few people get XP when they’re having a hard time? Not a big deal.
Also, my workouts are spec’d by my coach from TrainingPeaks. I have no interest/time to rebuild them to work around Zwift’s quirks. It is a good tip if you’re building your own though.
