Hi @shooj you moved my thread to a resolved thread. As this is closed I cannot interact with anybody. I have created this new thread as I do not know how to send private messages in this forum…
I already followed steps and cannot make it work. Location services are activated and not paired by bluetooth or Zwift app (today is on maintenance so this is not a problem).
I have a Samsung S9+ and Android 10).
I have recorded a video of the process, but cannot include any link on the post…
Unfortunately I can’t help you on your update issue but I can provide you infos about Links and PM: you have access to that only when you have reached the “member” status (trust level 2), that’s why you can’t do that for now…
As someone from Zwift team recommended by e-mail…I have also tested trying with airplane mode and wifi/bluetooth enabled, disabling 5g. But same result.
I think it has to do with the app, because in the process it can connect but stucks at bootloader…I have latest version from 12 october.
I did the new software update and now the hub connects to Bluetooth but no signal is sent and blue light blinks slowly and Zwift doesn’t have an answer.
I can get it to work through the companion app but the Hub shows Bluetooth connected and ANT not working when I just use the computer without the companion app.
after assembling my brand new Zwift Hub trainer I followed the setup guide and tried to make a firmware update with the iOS Companion app. After starting the update process on the Companion app, either the app or the trainer crashed.
The trainer is now showing the red LED, when opening the “Zwift Hardware” section in the Companion app the LED switches to a steady blue, but the Hub can’t be found by the app. Trainer switches back to red LED after a while.
I also tried to use another iPhone and turned Bluetooth off on mine, but to no avail.
Is there any hard reset or similar on the Zwift Hub? Has anyone else encountered the same issue? Or are there any other recommendations how to proceed?
I’d really love to start zwifting…
Shuji at Zwift HQ here. It looks like you contacted my Support colleagues via email, and they’ve replied with steps for a return / exchange. Please check your email and respond to that, as that process is done offline to protect your privacty.
