Cannot disable battery saver
Apologies if this has been addressed but I’m not able to find the answer. Battery Saver is set to medium and is greyed out so i cannot disable it. I’m on a desktop running windows 10. I was running windows 7 until last week and I’m pretty sure i could disable it then. Has anyone seen this before? Thanks
Edit: Not sure if it matters but all power saving settings in windows are disabled.
Hey Mike, can you try enabling your power saving settings in Windows?
Thanks for responding. Initially the power saver settings in windows were enabled, then I disabled them when I noticed Battery Saver enabled to see if that would help. However, when I got home from work today I went for a ride and Battery Saver was off right after Zwift loaded… So I’m not sure what happened. Must have been a fluke.
