I just purchased my TACX and I’m connecting thru Zwift, everything seem to be ok connecting but my garmin heart rate stripe wont connect. I tried both that I have also cannot. Is there any tip or trick to connect it? I tried my garmin watch and it’s ok but not the heart rate stripe that I normally use to ride and it connects well garmin gps not with Zwift.
You need to give us more info.
Which Garmin HRM (most are ANT+ only).
What device are you running Zwift on?
Are you trying to use Bluetooth or ANT+ or both?
The more info the better we can assist you.
Hi Paul, thanks for your reply, it reads here Garmin Heart Rate 3-SS and yes it’s ANT+ It came with my Garmin1000 Edge … is there a way I could bridge it thru the Garmin Edge to Zwift app? Any adaptor I should plug in my iPad Peo 11” to receive Ant+ signal?
NPE CABLE should do the trick: CABLEINFO - CABLE - Connect ANT+ to BLE (Bluetooth Low Energy)
Or buy a dual band HRM like the Wahoo Tickr or Garmin Dual.
Yes, I have one.
I heard there is a way to bridge the ant+ HR thru a Garmin Odometer device to Zwift app?
I don’t know anything about that.
