Can Garmin HRM TRI used for speed info for Zwift running when paired with CABLE?
Can Garmin HRM TRI used for speed info for Zwift running when paired with CABLE? I emailed North Pole Engineering to ask and they seemed to say that the Garmin HRM TRI would work instead of a footpod if connected via CABLE. Has anyone used this setup?
Thanks for any info.
Martin
The Garmin Tri HRM CANNOT be used as a running speed source for Zwift, it does not broadcast any kind of pace in real-time.
The only HR monitor that can be used as a speed source for running on Zwift is the Wahoo Tickr Run and Tickr X.
The NPE CABLE can however bridge the Garmin Tri’s HR to Bluetooth.
I corrected you in another thread also.
