Connecting my trainer to macbook pro was smooth and without issue.
Setup:
elite direto xr
Macbook pro
Bluetooth
Friend:
A friend of mine was unable to pair his trainer to a macbook air but worked fine on an Iphone 12.
Setup:
Macbook air
Wahoo Kickr Core
Bluetooth
Solution:
Having gone through all troubleshooting guides we ended up using Ant+ which worked right off the bat on my friends setup since mine was working fine
The other day my macbook lost battery and i had to connect my iPhone 12 instead.
Now my macbook pro doesnt find my trainer…
So… common denominator seems to be that if you pair your phone Zwift doesnt wanna pair to another apple device?
(We also tried an iPad without luck)
Anyone has a solution or encountered the same problem?
Yes it does matter, Zwift has a setting to use built in or the companion app, check the setting using the gear icon as i described. If it is set to only use the companion app for Bluetooth it won’t search for devices using built-in Bluetooth.
