Hello, I have a problem with the connection of the garmin 2 speed sensor, the sensor connects to zwift but it gives me 1 very low speed and therefore 1 estimated power is also low, which was not the case with the same size setting before wheel and roller but before it was connected by ant + in short, with the same configuration but with a bluetooth connection the speed and power data are much lower, any solution?
