I’m seeing some boxing of dust images that only started since the update.
Today at 3 points on TTT. italian village, through boat yard bit and on epic kom bypass. So assume all dust points will be similar.
Running windows 11 with RTX3070 in 4k.
Try a full restart (not shut down), if still the same it may require a reinstall. Suggests a dodgy asset or shader; it’s sometimes seen on water spray and tail lights too.
cheers will try later. I did do a full reboot since update yesterday to race today.
It restarts the Nvidia driver from scratch, that’s the only reason I mention it. It resolves the slowdown to the home screen ‘slide in’ effect when selecting a route, so there are obviously some things that stay in cache or memory.
I also get this new boxed dust effect Win 10, Nvidia 1050Ti on HD
Same particle effect squares for me. I’ll upload screenshots later. Definite new bug.
yup, confirmed as I saw it my ride tonight (windows PC / Nvidia)
Water and dust both affected. Also saw squares behind the triangle direction indicators on some riders.
Yep as mentioned on FB same here with dust/water boxes. Win11 12th gen cpu/RTX2060
Hard not to unsee once you know its around. Annoying.
This update has introduced the same problem for me as well. This is the blocky-looking graphics (particle effect squares) with the dust, water and turn-signal effects.
@shooj
I have the same block issue when rendering dust as others have reported here.
After the latest update I noticed that the dust isn’t rendered correctly. Instead of dust particles, the only thing I see now are large blocks moving around where the dust should be. These blocks are a slightly lighter color and transparent so they don’t affect the ride, but it’s not a good experience.
Computer: iMac 27" (5K)
OS: macOS 11
Graphics: AMD Radeon R9 M295X
Thanks for these reports and the screencaps everybody. Pictures of what you’re seeing are always helpful.
We’re looking into the cause on this. So far, a common thread appears to be desktop / laptops with very capable GPU’s. If you’re weighing in to this thread - please let us know which operating system and graphics card you’re using. Thanks
Win10/GTX1650Super
macOS 11.6.7 / AMD Radeon R9 M295X
Windows 11, Nvidia GTX 1060
Win10 and RTX 3060 Ti here, which with the above replies is already enough information to confirm it’s not OS/driver/GPU dependent.
Win10, GTX 1070 Ti mini
