Avator starts stops
Having written to support 20 times with only 3 replies one of which referred to rollers when I have a fluid direct trainer turbo muin I still have the same issue- I start and lose wattage - so basically starts stops starts stops etc - I have updated everything, deleted reinstalled and replaced Bluetooth yet still carries on !! And my sodding iPad dropped on ground and cracked screen - pretty peed off - any ideas as getting no where with zwift support - thanx
That sounds like you don’t have a good connection to the trainer or some interference from another device like headphones.
Sounds like a bluetooth connection issue.
Turbo Muin is a fluid trainer, the question is which sensors you use - the Misuro B is known for issues.
It is not a good idea to contact support 20 times - you will be on the end of queue with every new attempt.
