Hi can anyone help.Ive recently bought the Zwift controllers for my setup. I use apple TV. I’m using my iPhone to bridge the gap to get all Bluetooth connections.
All connections are active and you can see watts. However the Avatar doesn’t move.
If you are using Zwift Play controllers, do you see the brake light on? If so, you can disable the brakes:
OR see the following article on the Zwift website:
Hope that helps.
If the Zwift Play controller is causing the brakes to be stuck on, you can calibrate it:
This is only if Zwift Support asks you to do that, but I have had to do that to resolve a brakes stuck on issue.
Thanks Chris. That’s exactly what looks like happening now you have said it. The back light looks very bright and I was wondering That’s what it must be. I’ll look into disabling it.
Many thanks.
