Automatically makes me U Turn
Hi guys not sure if anybody else has had this issue. But when I start the new route a few pedals in it automatically makes me do a u-turn and delete the route that I selected. Any help solving this would be greatly appreciated. Thanks
Hi @Garrett_Gibson, welcome to Forums. It’s Juan here from Zwift.
I appreciate that you take ownership of this space seeking the support of the community. I see you have already opened a ticket. Keep an eye on your inbox as you have been connected to our support team. They will contact you as soon as possible.
I’m having the same problem. Can you please have someone contact me? It makes me want to break all the zwift things.
Email support@zwift.com to get assistance
Hi, i am having the same issue. Have you been able to resolve this? Thanks
If you’re using Zwift Play then it’s likely it’s a controller problem that’s causing this. Hold down Z for 30 seconds to reset the controllers, and also make sure their firmware is up to date. Failing that, contact Zwift support.
Thank you. There was an update available, which i have installed now. I will test it with my next ride.
I am having the same issue! Randomly keeps flipping a U-turn! I have held down both Z buttons for 30 seconds, and checked the controls are at the latest software level.
Contact Zwift support, e.g. via support@zwift.com
Juan, I’m also having a lot of trouble here. I’ve been extremely unhappy with the controls of this frame for the few weeks I’ve had it. The right control just disconnects all the time and I can’t shift. The left control keeps uturning at the beginning of a route so I lose the route. It has made the product virtually unusable unless I just want to do a uturn every few seconds. I have tried all of the troubleshoot steps including but not limited to power cycle, reset, firmware update, clean after every ride (always have), to no avail. I’m worried about not being able to return the unit even though I just got it. So far… I can’t do rides on this thing and it’s extremely frustrating.
Contact support ASAP because those controls may need replacing
Thanks Paul. Even before Uturngate and Disconnectgate I would have to try pair with phone/pair with Bluetooth alternations until they finally came up on the menu. You’d have to search and alternate those like 4 times. Yesterday’s route, I was 15 out if 20 miles in and my character just u turned…the controls were very inconsistent in the menus to the point where I gave up and just used Apple TV controller…then today that issue became constant and the right shifter just stops responding.
