Hi, anyone else having this problem since recent update (1.80 - December 2024) on AppleTV? Unable to pair power meter pedal and HRM using Bluetooth… checked that Bluetooth is enabled on AppleTV for Zwift App. Worked fine until the update… any solutions???
Try restarting the Apple TV? No other reports of this and if it were truly broken by the update there would be tons of reports.
Also make sure you force-quit Zwift after every session. Don’t just leave it running in the background forever else you can get various random problems.
Hi @Caro_Dube,
Welcome to forums, my name is Haziel and I’m part of Zwift Support. Let me confirm that Apple TV allows a maximum of 3 different BLE devices (including the Apple TV’s remote) to be paired at once, for that reason we recommend Using the Zwift Companion App as a Bridge.
If more assistance is needed, please don’t hesitate to reach out at support@zwift.com.
Thanks a lot for the suggestion… I did a restart and it worked (why didn’t I think of that?!!!)… it is the only thing I hadn’t tried… and now all works fine. Thank you!
Thanks for the suggestion, will make sure to do that…
