Android Supported Devices (UPDATED: Dec 22, 2019)
Why there is no support for the Samsung Tab A 2019? Some people reported that there was already support for the last version of the Tab A in 2018 and it worked. Please support the Tab A! You would make a lot people happier. Everytime i have to use my desktop computer :-(.
Hi fellow Zwifters. I want to buy myself a tablet in order to have a bigger screen. I am interested in Samsung due to bluetooth 5 and ant+. Which is the best tablet to look for, that are suported and will run smooth without problems for the next 3 years? Is it only the expensive high spec tabs that will work, or will the Tab S5e work as well? Or do you sugest saving longer for a top spec? It will be very sad to buy a tablet and find later its not compatibil or do not function correct.
Surely it’s time the Galaxy Tab A was supported…come on Zwift!! Please
Hi I use the Samsung Tab S 6 with no issues what so ever.i conects the TV and rarely drops out
Support for Galaxy Tab A 2019 should be a priority. It’s one of the hottest tablets.
Minimum System Requirements would be really helpful, since new android tablets are constantly coming out. Even if those minimum requirements are a moving target with updates.
There must be some minimum spec being pushed out on the Play Store, and some common denominator between all the working versions. So what is it?
Would be wonderful if tablets vs phones were kept separate. Like a lot of people, I’d love to know the cheapest possible ā€œRecommendedā€ and ā€œWorks OKā€ tablets.
Dears,
any plan to make the zwift app available also on Android TV boxes like Beelink GT King?
Even if equipped with good hardware and one of the most updated Android releases (Android 9.0), the zwift app is today listed as non compatible with the device.
do you think that with next releases you are going to extend the app compatibility?
today i’m using zwift through my iphone se…but it would be great having it on a box already connected with the tv…
thanks
ciao
I just bought a Tab A 2019 tablet to use Zwift on it. It seems I’ll have to use another software… That is very disappointing.
Maybe it’s confirmation bias, but I see some consistent posts about Samsung Galaxy Tab A 2019. I’m in the same boat as I have also just purchased this tablet as its specs, at least on paper, suggest it should be a great match for Zwift, and was surprised to find it is specifically disallowed. I don’t see why the 2019 model is being restricted.
My 3year android tv box runs the app, the box crashed and freezes sometimes, not only when running zwift. I just upgraded the box to one with more ram and faster processor and android v9, :frowning: not capable!
It’s run on my sm-t290 Tab A 8.0 inch
Hey, my friend has a Pixel 3a, and I have a Pixel 4 XL. We are both able to bluetooth pair to our Kickrs (I have a 2017, he has a Core) with our phones outside of the Zwift game (using our Androids), but if we remove the pairing to try to pair within game, Zwift never finds our kickrs (or my Wahoo Cadence pod). Any hints? Does Zwift not work on Android Pixels?
Thanks.
I.
I can run the app and have appeared on watopia but cannot connect my tacx flow Bluetooth trainer to the app
Works great on my Xiaomi Pocophone F1
When it’s the Samsung Galaxy Tab A going to be compatible? This tablet has been out since August 2018. Would like to try but want to do it on the tablet and not on my phone.
Have a bike on the way and would like to get an Android tablet that runs Zwift well. Would prefer to keep it under $200 USD. Any recommendations?
Tab A 2019 works
Hmm I just stopped by best buy to test it out. I can only see the companion app on the play store on the tab a 10.1
How does it work when you cannot even install it cause it says it is incompatible and the install button is not there?
Same issue with my BKOOL SMART PRO and Huawei p20 pro. Can not find the trainer as controllable device. Only as power and cadence sensor.
If you got solution please notify me.
Regards,
D. Balazs
