Currently, screen casting via Samsung Dex is not officially supported by Zwift. However, I’ve flagged up at HQ that it had worked until the Android 14 update for some, and I’ll keep an eye on @Jani_Raisanen’s workaround for future reference, especially if other Zwifters are not seeing it work as a solution. Thank you for calling this out!
Since Samsung update Zwift running on Samsung S23 Ultra no longer works with DEX in fullscreen mode. See images. Cannt get to run a ride ao unusable unless in non fullscreen mode but then its too small to read. All other apps in DEX are fine. Only since update on Samsung S23. Thanks
Thanks for that Paul ill give that a try tomorrow. I went back to chromecast and casting my entire screen that works so i have a couple of options. Ill let you know how i get on and thanks once again for the reply.
Thank you JANI post #19
Hi I had same problem, but could by-pass it in samsung setups: advanced features > labs > multi window for all apps. After that Zwift opened directly full screen mode and resolution was good.
the only thing that need to add is restart of the phone and it worked all good back to normal as it was!!!
thanks a lot man
Hi, i had the same issue with my new Samsung S24 / Android 14 device, fixed it as described, but the font size in Zwift is now bigger than on my older device running Zwift in Full Screen on DeX. Any ideas how to fix it? Adjusting font size in the DeX settings doesnt work.
Thanks,
Hi @Sebastian_Morick, welcome to Forums It’s Juan here from Zwift. Alternatively, you can try in-game settings to adjust the display scale. It appears as Display Scale. There are currently five options available for Home Screen Scaling:
