I’m level 17. Trying to find Alpe Du Zwift route. I see other routes, but not AdZ, which I understood I could get to if Level 12 or higher.
Help please.
Help please.
Hi )
Search for Tour of Fire and ice route on Watopia map: https://zwiftinsider.com/tour-of-fire-and-ice/
Or for Road to Sky route: https://zwiftinsider.com/road-to-sky/
Road to the sky is the shortest way to get to the Alpe but you do have to ride through the jungle and will be slow due to the update they made to the drag coefficient of dirt.
Select “Jungle Circuit” but make a manual right turn for the Alp as the fastest way to start.
@Zee_Kryder you won’t get the Route Completion Bade & XP for the badge if you do it that way though.
Spot on shortest way
