8 weeks of zwift, my impressions thus far
@Adrian_Anastas_BCG
What are your pc specs?
Where was this promised?
:scream:
Then there’s something totally wrong with your PC.
I’ve seen some other threads where zwift mods, or devs have made comments of future improvements.
That was my initial thought. But nothing else runs slowly. After uninstalling, reinstalling, virus checking, malware checking, windows updates, windows rebuilds I’m still sitting around for 15 minutes plus waiting for Zwift to load.
Today I started Zwift at 6:40 for a 7:00 am Activity. To my horror I got the dreaded ā€œAn update is neededā€ dialog. By 6:55 while still waiting for the update to finish I had enough. I’m done. The Trainer came with a free Rouvy trial. By 6:58 I’d registered, downloaded, installed connected sensors and started my ride. The most annoying thing about it was at 7:10 when Zwift finally popped up and blocked my view.
There is something seriously wrong with that PC. Even the Zwift installation on my wife’s pentuim 10year old pc is faster (about 3 minutes)
EDIT: it is a Core2 Duo E8500
Probably a Celeron or Atom, or non-Ryzen AMD. Coupled with a mechanical hard drive.
It’s massively underestimated how important the CPU is to virtually every aspect of Zwift performance, including load times.
A common (ish) issue I’ve seen with Zwift is mismatched MTU (maximum transmission unit). Assuming you have a windows box then open a command prompt and type
netsh interface ipv4 show subinterfaces
This will show a series of interfaces - one with a very big number and others (maybe only one) with a number about 1500. This laptop shows 1500 for example on the WiFi interface. Picking the interface you actually use then find the MTU and subtract 20 from it.
Now type in the command prompt
ping -l 1480 -f 8.8.8.8
8.8.8.8 is the IP address of Google’s DNS servers. If this comes back like
Pinging 8.8.8.8 with 1480 bytes of data:
Packet needs to be fragmented but DF set.
Then you have a problem. It’s easily solved but a bit involved - let me know if you have this issue.
Hi Paul,
I’ve already maximised my MTU to account for any Latency. My optimal MTU is 1472, so when I add 28 to that (20 bytes for the IP header and 8 bytes for the ICMP Echo Request header) I’m back up to 1500 anyway. I did try lowering it on the PC and it made little difference. I’d expect latenmcy that is causing minutes worth of delay would affect all applications and not just Zwift.
It was about 2-3 Minutes when I first installed. But Every Update seems to make it slower. I’ve been Using Rouvy under a free trial for the last week. It loads in a minute or so. Thought I’d try Zwift again today, and yup, another update and another 30 minutes waiting for the thing to load before I gave up.
AMD A8
Once the thing loads it runs well, its just the blasted start-up time
