100kph badge tips and tricks
Hey all! I just got the 100kph badge after failing out of it a few times and thought I’d share a few tips. I am a decidedly vanilla, Cat-D, 75kg rider so if I can do this, there’s a darn good chance you can too.
Bike Frame & Wheels
I failed this using the stock Zwift TT bike so it’s possible you’ll need to level up enough to buy something more aero. I happened to hit L26 recently and unlocked the ”Canyon Speedmax CF SLX Disc”, known to be one of the more slippery TT bikes. If you’re not at L26 yet, the Cervelo P5 is available at level 15. I already had the Zip 808 wheels (L13 unlock) but the very good DT Swiss ARC 62 are available at level 6.
I suspect - after failing my first attempt - aerodynamics play a part. However, I also mis-judged when to use Aero-Boost and apply power during my failed attempt. If you’re successful with the Zwift TT bike, let me know!
Route
The Radio Tower descent is probably the most accessible place to try this as it’s along several routes in Watopia (Epic KOM or the reverse). The super easy, almost-feels-like-cheating-way to get there: Join Pace Partner A. Anquetil while he’s riding the “Three Sisters” route and nearing the KOM arch.
Strategy
Riding through the Epic KOM arch, I didn’t get the Aero Boost power-up the first time so I dumped it, rode to the Bonus Climb (aka “Radio Tower”) turn point, went around the corner and then U-turned back to the KOM Arch, with another U-turn to go through again for another chance at the Aero Boost. (took me a few tries)
EDIT: You must be riding a non-TT bike when crossing the KOM arch - Aero Boosts aren’t awarded if riding TT-bikes.
Once you have the Aero Boost, head up the Radio Tower climb, go slow, even setting “trainer difficulty” to OFF if you just want to zone out at a constant wattage and cadence. Take special note of the sections with the steepest gradients - there are a couple of corners around halfway up that hit 16-17%. You’ll want to remember where those are (maybe take a screen capture for later review) so you’ll know when to activate aero-boost and spool up your wattage on the descent. On my first attempt, I think I got antsy and activated Aero Boost too early which had it running out before hitting the steepest sections.
Prep & Descent
Once you’re at the summit, stop early so you have some runway to get up to speed before the descent. Take a breather (especially if you just did the entire Epic KOM without the pace partner help) get off your bike, stretch out your legs, have a coffee.
In your garage, equip fast TT bike & wheelset (change camera angle to confirm it took), in Settings, dial trainer difficulty to “OFF” (0%) to prevent spinning out, and consider having a secondary device running the companion app for easier Aero Boost activation.
  • Starting the shallow descending section of the loop, ramping power up (I held about 300-350Watts) - if you hit about 85kph here, you’re on track to make it.
  • DO NOT use Aero Boost too early (wait for the steep corners farther down)
  • Approaching the first steep corner, ramp up power (I doubled mine to 700Watts), hit aero-boost if you haven’t already. You should hit 90-95kph here and see speed climbing. The second steep corner comes fast so you won’t have to hold this for more than a few seconds (and Aero-Boost only lasts 15seconds) as gravity assist in the steep sections pushes your speed up.
I suspect there’s a large stretch where you can hit 100kph and it’s between the two steepest sections - if you miss it on the first 17% turn, you’ll still be accelerating down and can hit it on the second. The kiss of death is if you go hard or apply the Aero Boost too early where it won’t stack with the gravity assist.
My terminal velocity was 105kph, just before the last turn near the bottom of the Radio Tower hill. (look carefully at the mini-map in the image below - also note my Aero Boost is just about to run out…)
TL;DR: fast TT bike & aero-wheels, trainer difficulty to 0%, don’t sprint or hit the aero-boost too early - the steepest sections of the Radio Tower hill are closer to the bottom.
Nice, congrats on the 100kph! I tried this before I was level 26, so used the Specialized Shiv Disc TT frame which you can get at L18, I also did this on the Radio Tower climb.
I didn’t get an Aero boost but didn’t want to keep lapping until I got one (partially because I didn’t know how long it took to reset the bonus), so I did one effort to try to get the 100kph without the Aero boost just to see, knowing that I might need to go and try again. Turns out I got super lucky, I hit exactly 100km/h on that run without the boost, but I went as hard as I could to get it, and almost missed (I don’t have great short term power - so I’m sure this is much easier for folks who are sprinters), so definitely worth getting the boost I think.
I got the badge on a cat D group ride in Bologna using the Buffalo bike. The ride leader asked us to wait at the top of the climb and many of the riders did. On the descent I just rode in the pack without pedaling, and voila, everyone got the badge easily! I think I reached 106 kph.
Too cool! Sounds like the ride leader had that little surprise all planned out!
Another vote for the Bologna downhill being far easier than the Radio Tower for getting the 100km/h badge. I did it on a Tron bike without needing any powerups - had to pedal fairly hard for a bit to get up to about 85-90km/h in the early part of the descent, but after that went into supertuck and let it do the rest. Think I hit just over 102 at maximum.
Great datapoint Steven. I’ve never ridden Bologna as it’s Event-Only but Supertuck on a non-TT bike is an interesting option. Given it’s such a short course (8km), and you’ve done it without a high-end TT frame and wheels, it’s probably more accessible to lower-level riders.
I want to try this myself now and see if I can hit 100kph using a mid-tier non-TT bike.
One extra tip is not to relax when you see the 100kph appear on the screen, keep hammering the pedals. I’ve discovered to my cost that afterwards the ride was recorded as 99.7kph and no badge. Damn that rounded up speed display.
Otherwise agree: TT bike, radio station, aero token, pedal like crazy, smile.
I thought you could only get the XP bonus powerup while riding a TT bike. Did you have to use a road bike to get the aero boost powerup, then switch to a TT bike?
Has anyone done this on the KOM in New York? Pretty sure it has the steepest gradient in Zwift (18% if I’m remembering correctly).
…yeph, missed that. Change bike at the top, else you’ve made that climb harder than it needed to be.
Ouch! Yeah, I kept pedaling like a maniac until I saw the achievement banner show up. I think on Strava it showed up as 99.9kph actually, but I did get the achievement, so I’m calling it good enough :slight_smile:
Interestingly, in line with what you wrote, my activity log online shows a max speed of 104.4kph.
Ah, yeah good point there. I edited my original post to reflect that.
If someone forgets about it though, all’s not lost - switching to a non-TT bike and doing the Epic KOM arch again (as I described doing) will work.
Related - I got the 1100 watt badge the other day, let off the power when I saw the banner, and after the ride, both Zwift and Strava said my max watts was 1192.
8 more watts, and I would have had the 1.2Gigawatt badge.
The descent in NY isn’t steep enough for long enough to get up to speed because it’s a series of ramps - between the bits that are 15% or 18%, there’s small sections that are only 2% or even flat, and that completely breaks any chance you have of hitting the higher speeds.
Seems like doing the Bologna would be more practical as it seems to take less time.
I hit 97 km/h coming down Ventoux after the Rapha Rising ride yesterday. Aero boost, accelerate into someone’s draft, hit it at just the right spot (sorry, can’t remember exactly where I made my attempt). I was on the Aethos and Lightweights - probably would’ve got it if I’d switched to an aero frame and disc wheel or Tron bike. 72 kg, max power was 660w.
Do you have a tip on the 700 watts lol?
700w -1000w badge.
When you go down the epic KOM you will see a bump just around the hair pin, if you speed up and hit that bump as hard as possible you will most probably unlock the badge.
Wait, so is there a different place to do the 1100 and 1.2 Gigawatt badge? :slight_smile:
Stand up with gusto :grin:!
Got mine today. Coming down the Bologna hill. Canyon 2021 Areo helmet power up. Supertuck.
Hit the power up at -13% Hit 100 in the 16% section, I think.
I’m 64 kg, so this should be possible for almost anyone.
