Zwifters seeing different (or no) red sweeper beacons in the same event subgroup [July 2022]
Hi @Mister_Tz
I merged your post into a discussion already under way. We are in fact working on a fix for this on the server end that we think will improve this bug.
The fix is not complete yet - we’ll update this thread when it is, and ask you all to keep an eye out to see that this no longer happens.
Cant wait, we had a Red Beacon today on the PACK ride, just a shame no one could see it…
Good day team. Seems to be a problem after the new update that some zwifters cant see the red beacon. Please investicate. Thanks.
It’s already being looked at and potentially fixed in the very near future.
Server side changes have been made.
any rough ETA on this.
Our ride today was messy with 6 riders from the sweep list on the ride it was like sweeper bingo on what people saw.
@Rhino-Racing
No ETA, we’re still working on this one. It gets more complex as we dig into it.
Just updating you that we also still have this issue. Could it possibly be due to the timing of entering the pen before the event start time? IE: If you enter under 30 seconds before start.
It’s definitely tied to it; this is why I don’t usually join the events I’m a beacon on until 1 minute to go.
It doesn’t seem to be device dependent though; as other Windows users have the issue and I don’t think I have.
But essentially it’s just like some people who are in the pen for long enough, a red beacon might not “step up” to the next person higher on the list, but get stuck from the first red arrival.
As red beacon if I left logging in until the last minute or 30 seconds then we usually had 2 or 3 other red beacons. Last time I logged in 12 minutes early before just about everyone else and it was the first time ever that I was the only red beacon (the ride has only been going for 3 or 4 months). Every ride for the last few months we have had multiple red beacons when I logged in usually less than 1 and a half minutes to go. I use windows for Zwift.
This is what I mean when it doesn’t seem to be reliant on device.
I have never once experienced this issue on my end except that one singular time I posted about earlier; but clearly, something is causing others to.
Do you usually join the pens before the sweeps?
i suspect i join quite early and not sure i see it as often as others
If I’m yellow I’ll join anywhere from 5-3 minutes to go.
if I’m red I generally join with 2-1 minutes to go.
But the people I’ve heard from seem to have these issues no matter when they join.
as an aside sometimes rejoining helps.
yep it does seem rather random. we even tried getting the wrong beacon to leave and late join again and they still stole the beacon back in some (but not all) riders view
I’ve removed ALL backup RED beacons from AHDR events until a fix. It’s the only solution for now.
@Mister_Tz, @Andrew_Nuse, @Peter_Parnaby, @Rhino-Racing, thank you for keeping us updated. Do you recall which events you were in most recently when this issue occurred? I’d like to pull logs for tracking.
Yesterday’s BMTR Short Adventure D ride at 8 est had this problem.
I’m not seeing a pattern with late joining.
It’s still random on my daily event as to if it happens.
Today i noticed the yellow beacon wasn’t showing on the mini map.
Hi Rowdy. It was happening every week in the Zwift - Group Ride: SZR Sunrise Ride (E) - note there is a (D) ride as well - held on Monday 3.45pm eastern Australian time. Every week we had 2 or 3 red beacons until the last 2 weeks when I logged in early before most other people (each of those last 2 weeks there were 2 people already logged in). I was the designated red beacon. I logged in 10 and 15 minutes early and we haven’t had an issue those last 2 times. There were lots of other listed red beacons also present on those last 2 times. So no issues on 7th October and 30th September.
Previous rides on 2nd, 9th, 16th and 23rd September there were multiple red beacons, and pretty well every week before September as well. The ride is reasonably new and has only been going maybe 6 months.
Before the last 2 weeks I was logging in more like 30 seconds to 2 minutes before the ride start.
Hi Rowdy,
I’ve pulled all back-up REDs for the past week. The last event was this one with issues: ZwiftPower - Login (events.php?zid=4522371)
Cheers,
T
We’ve been having this issue on the BMTR Short Adventure D rides for quite a while now. As Lebasi mentioned, we had people seeing three different people as Red Beacon this week.
I had thought about clearing out the roster and only leaving the designated Red Beacon as the sweep, but I’ve seen on other rides that in that scenario some people don’t see a Red Beacon at all.
The only other thought I had was making the changes to Red Beacon futher in advance of the ride. We change it around almost every ride and sometimes those changes are made just before the cut off time. Red Beacon for our ride on 10/9 was set well in advance, and there didn’t seem to be any reports of people seeing the wrong person with Red.
Just a theory :slight_smile:
