My setup has been and was working fine but after the latest update zwift wont display on my tv. hdmi connected, loads on the laptop shows on the tv but after the first couple of screens as it goes to the blue logon screen it no longer displays on the tv and goes back to the desktop screen…but it carries on loading and works fine on the laptop…any ideas, thanks.
It sounds like you’re mirroring from your laptop to your TV. Do you have the game set in fullscreen mode? Depending on your resolution, there could be issues with it displaying, so I’d recommend trying windowed mode to see if it makes a difference.
Thank you very much Jason…you are a life saver! I was having the same issues with mirroring my PC to my TV and switching from ‘full screen’ to ‘windowed’ modes as you suggested did the trick…thanks again and keep up the good work.
I have the same problem, but it wont let me select the windowed mode?
