Zwift to Garmin Connect
Hey all,
I was wondering if the activities (automatically) uploaded from Zwift to Garmin Connect contribute to Garmin’s Training Effect, Load and Training Status?
I have an Edge 1050 for outdoor riding but I don’t plan on using ERG mode, FYI.
I also have a Garmin HRM-Dual and MacBook Pro 2021 M1. Not sure if this is relevant, though.
Yes, Strava treats Swift rides the same as real rides for training statistics.
Thanks for your answer but I wasn’t talking about Strava. I was specifically refering to Garmin Connect, they have their own Training Effect, Load and Training Status.
Yes for cycling you get the full metrics such as load etc…
Without having to use my bike computer? So weird because I see lots of people having to double record; one on Zwift and one on their bike computer to get that data…
Because those values are not part of the data being transferred. The fit file is just your power, cadence, speed, heart rate, and GPS data. All the other stuff is being calculated from that information at the receiving end.
The double recording is something totally different… That’s usually for data verification in the more serious virtual race events.
Most data transfer. But I don’t get Garmin’s stamina data unless I record directly on Garmin. Also, my understanding is that results don’t count for Garmin challenges/badges unless recorded directly on Garmin, so I think some people double record to get credit for those.
This is correct, though one can modify the Zwift-generated .fit file to change device type to a Garmin in order to resolve this.
to get the garmin stuff you need to record the ride on a garmin device
Even on this topic some are saying the automatic upload from Zwift to Garmin is sufficient while some are saying I need to record on a Garmin Edge device. I wonder where the confusion is coming from.
But what about the answer from people saying it’s not needed to get Garmin’s Training Load and Effect? How come some say you need to double record and some say upload from Zwift is enough?
I don’t need the badges or challenges or stamina. I only want the Training Effect, Load and Status on Garmin Connect. Distance, duration, power, speed, calories as well but I believe those are always included.
Training Effect is calculated on a Garmin device, not within the Connect App/Web.
Not all Garmin devices have this calculation logic.
If you record only on Zwift, then your .fit file can be synchronised to Garmin Connect.
When you synchronise your compatible Garmin device with Garmin Connect it will receive that data and perform the necessary calculations.
When you synchronise your Garmin device a second time, Training Effect etc will appear in the Garmin Connect App/Web.
This is how it works with my Fenix 6 and/or Edge 530.
Aha, I see. That should work.
So sync twice; once for receiving the ride from Zwift and do the calculations. Once to send the calculations to Connect.
Im new to zwift , i have hrm run (ant +) so i dont have bpm on zwift(im using phone) so i run activity on zwift and on garmin . Today i try only on zwift , dáta is transfered to Connect like distance , speed, watts but i dont have training load , effect, recovery…
Have you ever recorded an outdoor ride on your Garmin? There is an earlier thread that discusses the need for a “seed” ride on Garmin before those metrics show up when you only record on Zwift. It never made sense to me, and I’m not sure it is still true, but it was an issue when the metrics first became available using Zwift only.
Of course, i have training status on garmin but not from zwift activity . Problem was missing heart rate from zwift. I use zwift on phone so there is only Bluetooth connections and my heart rate monitor has ant + but fenix Watch can send heart rate from wrist sensor so then it works .
