Zwift keeps getting stuck on the final “Patching” stage. Running macOS Monterey V 12.7.6 on a Macbook Air Early 2015 model. Can’t see anything that suggests it won’t work with this - I know it won’t be the smoothest but it still should work right? Anyone else having a similar issue - this is my first time installing and running Zwift
Hello @Sion_McGregor
Shuji at Zwift HQ here. Is this a hackintosh that’s running an OS newer than what’s officially supported by Apple?
More specifically - is the hardware capable of supporting the Apple Metal graphics API? Zwift will run on Macs that support Metal.
The 2015 MacBook Air supports Monterey natively and Metal is available on 2012 Macs or later. Probably something else.
If it supports Metal, we may need to do some one-on-one troubleshooting with you.
See this support article first, then contact Support (there’s a link).
