After the update Zwift is showing much higher watts. I’m using a speed and candans sensor form Garmin. How can this be fixed?
If you’re on a dumb tacx trainer, swap it to an elite nova force, worked well for me. Comparable figures.
I have this same issue. I’m normally outputting 250 watts after the update i was cruising around at over 400w. Nothing on my hardware side has changed. The only change was the swift update.
Same here. Much higher watts indicated than I know I was actually doing. FTP has changed from 288 to 450 watts!
Hey folks - to save too many threads opening up on this issue, can you post over in this thread below.
Zwift are asking for info from you to help them troubleshoot
