Hello,
Im thinking of buying a Zwift ride to lose some weight. Im around 125 KG today, and the limit seems to be 120 KG. Do you think it will be any problems using the ride?
Hello,
Hello @Jens_Olsson1 and welcome to the Zwift forums. Most of us here are just regular users and not official Zwift staff. I highly doubt anyone from Zwift HQ will chime in and tell you its fine to exceed the rider weight. However, you are only 5kgs or 10lbs over the limit and I’m sure it was tested at much higher weights than 120kgs… so it would probably be fine… but ride at your own risk.
Thank you!
Yeah i figured that out, should be fine i think.
Worst case scenario you will read in the new about a death on a zwift ride
The weight limit for Wahoo trainers is 113kg but I wouldn’t worry about it.
For comparison:
Tacx Neo 2T 125kg
Saris H3 136kg (rider + bike)
I don’t know if the other manufacturers are talking specifically about body weight or rider + bike. Anyway a lot of big people ride all of these trainers because that’s what they have to do, no better options.
