Zwift Ride with Kickr Core 2, very hard
They had me do a pyramid power test using the wahoo app and share the results. They are sending a replacement after reviewing them. Hopefully the next one works.
Have you tried connecting the Core to the Wahoo App and comparing the power numbers during a ride?
My core 2 seems off when standing too. Seems like I should be putting out 400-500 watts and it’s only giving me like 300. Did you get a new unit and is it better now?
I’ve had my Zwift Ride and Kickr Core 2 for a couple of weeks and have had the same issue with resistance on the Core 2. It’s waaaaaaaay too hard. Did a hilly race on Sunday, thought I was just having a bad day but now I’m convinced it’s seriously under-reading. When I was descending I could barely turn the pedals on the harder gears even when doing 70kph.
FWIW I’m an experienced rider/racer, been on Zwift since the start, been using a power meter for a decade, coming from a standard geared bike and an original Kickr.
I think it’s an issue with the auto-spindown not working properly. When I first got it a couple of weeks back there was no way to do a spindown in the Wahoo app. Then I ran a firmware update over the weekend and they now give you the option to do a spindown, which I’ve done, but not had chance to test it yet. Going to dual record with my Favero pedals and check it. Will report back.
Have you tried changing the wheel size setting in the Wahoo app? Even if it looks right, change it down a very small amount.
Pretty sure wheel size is irrelevant on a direct-dive trainer without wheels?
it is, but there was a bug that helped resolve things if you changed the size of the wheel.
Ah ok - thanks, will give it a try.
Very common firmware bug on the Core V1 but I’ve never heard of it affecting a V2. Would be quite interested to know if it helps. On the Core V1 the wheel size would somehow get set to a null value which broke virtual shifting.
On the Wahoo trainers I’m pretty sure it uses the wheel size when it sets the base resistance for 0% incline.
I did the new spindown yesterday and just finished a 45-minute race with dual recording. The Kickr Core 2 still reads about 5% lower compared to the Assioma Duo. The Analysis is public on ZwiftPower.
As you likely know, there’s always going to be a bit of a discrepancy between parameter pedals and smart trainer with a smart trainer, usually reading a bit lower. That said, I’m curious, did you do a factory spin down or a regular spin down?
I did the Spindown which is now available in the Wahoo App for the Core 2. What is the difference?
That seems within reasonable limits. The Core 2 is accurate to within 2%, and the Assiomas to 1%. So with a couple of percent or so drivetrain losses as well that sounds ok to me.
See the section titled New spindown (CORE 2) to learn more about that feature
https://support.wahoofitness.com/hc/en-us/articles/20511099871634-Factory-spindown-KICKR-MOVE-CORE-SNAP-tsg
In addition to Paul’s link. Here is an article from ZI explaining the difference between types of spindowns.
Quick update - I compared the power reading from the Kickr Core 2 to the power reading on my Favero Assioma pedals. Sure enough, the Kickr is under-reading by around 60w. No wonder I was struggling in the hilly Zwift race on Sunday!
Tested Zwift with power coming from the Favero Assiomas and the Kickr Core 2 controlling resistance and it’s still comedically hard. 20 RPM in the hardest gear when going down a 7% hill!
I think it must be faulty. Sent a support ticket to Zwift to find out what to do next.
No idea if it would help but have you tried this:
https://support.wahoofitness.com/hc/en-us/articles/115000506290-ANT-power-meter-trainer-control-with-the-Wahoo-app
I will have to try the spin down and changing wheel size. I have a quarq and saris h3 and the power from those were very similar. I want to put the quarq on the core 2 and see what it says.
Is there an update about your situation? I‘m having the exact same issues on a brand new kickr core 2.
