Zwift ride empty stocks December
Planning to buy a Zwift Ride as Christmas present. Do I have to worry about delivery bottlenecks and empty stocks in December?
Regards
If I was buying one as a Xmas present I’d want it early enough to be able to unbox it and set it up, then test it well before Xmas. Just check the number of faulty/damaged devices reported on this forum (which we can only suspect is a subset) and the problems with delivery/replacement.
I believe that Zwift are looking into the packaging and delivery process in order to reduce the number of returns but that could take weeks/months before any changes are implemented.
Thanks Colin,
definitely a problem I did“nt consider yet. Thanks for this kind advice! I will go through the reports to get a better idea of these issues.
Regards
Christian
There is no way I’d be buying a Zwift ride until they sort these issues out. The amount of posts on here about ā€œdamaged in transit itemsā€ and then the difficulty of returning/receiving a replacement puts me right off. I was ready to pull the trigger but I’ll wait until the situation improves.
it is back in stock at least for germany at the moment
Ordered, thanks.
Good to know! Thanks.
