My PD-curve has a constant value from 0 sec to 20 sec.
Something is blocking off all values over 527 Watts.
My WKO5-App is showing the correct curve though…
Why does ZwiftPower show a wrong curve?
Welcome to the forum.
That usually happen if not all the data is uploaded. give it a bit of time and it should update.
Change your Privacy settings to Public if you want accurate data; private or restricted activities do not allow zwiftpower to pull a fit file.
Thanks for the reply!
I changed my profile to ‘public’ and participated in a new race today.
The problem remains… no data from 1s to around 20 s on the PD curve, which shows a flat line.
I can see in another thread, that the problem is quite common…
You have to usually give the system a few hours to update after an event.
Green line is from your event today. Note also the blue lightning bolt on your profile indicating zwiftpower pulled a fit file.
Yes it works - thanks!!
Hi ![]()
Do you know if I didn’t set the ride to “public” initially, but changed it just now, will Zwiftpower “re-update” and build a correct powerprofile?
(I also just changed my profile to “Public”.)
