Zwift Play Controller not playing well with my New Computer
Good Morning Zwift Friends!
I have been runnng Zwift for a number of years now on my Dell Alpha R2 computer (7 yrs old) with Wahoo Kickr trainers from v. 4 to the v. 6 that I currently have.
I also have both the Zwift Click (purchased 1st) and the Zwift Play Controllers (which I now use exclusively). These have functioned fabulously with this older computer and all the various version of the Wahoo Kickr.
However, I decided to upgrade my computer (this past week) and now have a locally built computer with much higher end specs on which I have successfully installed Zwift. And Zwift now comes up much faster and I even gained the 15 sec video clip icon in game! So far so good!
Sadly however, I have not been successful in getting my Zwift Play controllers to show up in the configuration screen so I haven’t been able to ride ‘as I normally do’ with shifting and directional control! I really thought that the newer, higer end computer would work out of the box, but alas, no. :cry::unamused_face::sob:
I ride daily and also race every Thursday in the weekly TTT and not having shifting and directional control means I’m a no go. So, this is a must have for me! :folded_hands:
Thanks for any help you can provide.
FYI… I have read as many posts as I could find in trying to find a solution but no joy thus far.
does your new computer have bluetooth built in or are you using an external dongle on a usb extension cable?
Built in…
SPECS
KR+ Core i5 (14th Gen) i5-14500 Tetradeca-core (14 Core) 2.60 GHz Processor
Asus Prime PRIME B760M-A AX Desktop Motherboard (with bluetooth)
Kingston 16GB DDR5 SDRAM Memory 1
Upgrade to Samsung 870 EVO 1TB GB 2.5" Internal Solid State Drive SSD- SATA
DVD-RW Drive 1 0.00 0.00T
Ugrade to Asus NVIDIA GeForce RTX 3050
Microsoft Windows 11 Pro 64-bit
are they connecting on the pairing screen when you start up Zwift?
FYI, some built in bluetooth antennas are really crappy, so it might just be a bad part with not a lot of range. What happens if you place the play controllers right next to the PC? If they connect when really close, maybe it is just the antenna inside the PC.
Computer, bike and trainer are within 4ft of each other.
ZP does not show up in the ‘Connection Screen’.
have you checked and updated the firmware on the play controllers using the companion app recently?
You can also hold down the big Z button for 30 seconds and do a hard reset on them, see if that helps.
I updated the firmware yesterday…no joy. I haven’t tried resetting. If you think that will help, I’ll do that when I get home from work.
Thanks for commenting…
I have encountered new PCs recently which had terrible onboard Bluetooth performance, all cleared up instantly after disabling the adapter in Device Manager and using a TP-Link UB400 on an extension. Lots of other acceptable dongles out there as well.
Thanks, Paul… Great minds?
I actually ordered a TP-Link UB500 yesterday which should arrive today. :crossed_fingers:
