Zwift on Windows PC. Extreme Lag
Been using Zwift on PC for 8 months now with no problems and all of the sudden the desktop app is extremely laggy and has become unusable. It’s pretty much freezes up at the initial connections menu and the app is “Not Responding”. This started yesterday after I updated to the latest version, not sure if related or not.
I’ve recently added S4Z mods and had them working seamlessly for a few weeks so doesn’t seem related to that. I’ve uninstalled and re-installed the app, deleted all documents files when doing so but nothing has worked. I’m running Windows 10 for what it’s worth and I’m at loss for why this is happening. Would appreciate any help and I can upload logs if needed. Thanks in advance!
This sounds like an occasional bug that shows up when using ANT+ and Windows. Try the solution over here:
not sure if it’s the same bug exactly but when that happened to me on PC, the fans on my GPU stopped spinning until i restarted the PC entirely, even after closing zwift and ending all the processes. seemed to work fine again after that, and it hasn’t happened a second time
i don’t think it’s a hardware issue
Thank you Paul, this seems to be the issue. Was close to swearing off Zwift!
