Zwift on PC freeze after login
I have a problem with the Zwift on Windows. The ZwiftApp.ext freezes just after login when it’s showing the main menu.
I’ve tried uninstallation with deleting the zwift folder in the Documents, but nothing has changed.
I’m a new comer of the Zwift, so I don’t know it worked in the previous version.
Also, I tried on the MacBook Pro, which has an M1 processor, and it worked well, but I’d like to use my Windows machine.
My computer’s spec is:
  • OS: Windows 10 22H2 19046.3448
  • CPU: Intel Core i7-7700K
  • Memory: 32GB
  • GPU: NVIDIA GeForce RTX 2060 SUPER
  • Display: 4K 144Hz
The logs are the bellow.
[22:35:49] Log Time: 22:35:49 2023-09-23
[22:35:49] Game Version: 1.48.0(120544) rc/1.48.0
[22:35:49] Config:       Shipping
[22:35:49] Device:       PC
[22:35:49] [OS]: Time resolution(1000)
[22:35:49] [OS]: Initialized
[22:35:49] [ZWATCHDOG]: Initialized
[22:35:49] Launcher Version : 1.1.10
[22:35:49] DEBUG LEVEL: Open assets/global.wad in file 0xd774ec70
[22:35:49] Loading WAD file 'assets/global.wad' with file.
[22:35:49] DEBUG LEVEL: Close file 0xd774ec70
[22:35:49] DEBUG LEVEL: Open assets/globalproj.wad in file 0xd774ec70
[22:35:49] Loading WAD file 'assets/globalproj.wad' with file.
[22:35:50] DEBUG LEVEL: Close file 0xd774ec70
[22:35:50] DEBUG LEVEL: Open assets/Worlds/worlds.wad in file 0xd774ec70
[22:35:50] Loading WAD file 'assets/Worlds/worlds.wad' with file.
[22:35:50] DEBUG LEVEL: Open assets/Environment/Ground/textures.wad in file 0xd774ec70
[22:35:50] Loading WAD file 'assets/Environment/Ground/textures.wad' with file.
[22:35:50] DEBUG LEVEL: Open assets/UI/WhiteOrangeTheme/WhiteOrangeTheme.wad in file 0xd774ec70
[22:35:50] Loading WAD file 'assets/UI/WhiteOrangeTheme/WhiteOrangeTheme.wad' with file.
[22:35:50] DEBUG LEVEL: Open assets/UI/minimap/minimap.wad in file 0xd774ec70
[22:35:50] Loading WAD file 'assets/UI/minimap/minimap.wad' with file.
[22:35:50] DEBUG LEVEL: Open assets/UI/WhiteOrangeTheme/Scotty/Scotty.wad in file 0xd774ec70
[22:35:50] Loading WAD file 'assets/UI/WhiteOrangeTheme/Scotty/Scotty.wad' with file.
[22:35:50] DEBUG LEVEL: Open assets/UI/layouts/layouts.wad in file 0xd774ec70
[22:35:50] Loading WAD file 'assets/UI/layouts/layouts.wad' with file.
[22:35:50] DEBUG LEVEL: Open assets/Environment/GrassTextures/GrassTextures.wad in file 0xd774ec70
[22:35:50] Loading WAD file 'assets/Environment/GrassTextures/GrassTextures.wad' with file.
[22:35:50] DEBUG LEVEL: Open assets/configs/buttonconfigs.wad in file 0xd774ec70
[22:35:50] Loading WAD file 'assets/configs/buttonconfigs.wad' with file.
[22:35:50] DEBUG LEVEL: Open assets/gearing/gearing.wad in file 0xd774ec70
[22:35:50] Unable to open WAD file "assets/gearing/gearing.wad".
[22:35:50] ERROR: Could not load wad file: assets/gearing/gearing.wad
[22:35:50] DEBUG LEVEL: Open assets/haptic/fittech_haptic.wad in file 0xd774ec70
[22:35:50] Loading WAD file 'assets/haptic/fittech_haptic.wad' with file.
[22:35:50] ERROR: Sky::Load(): Japan not found
[22:35:50] ERROR: Sky::Load(): France not found
[22:35:50] ERROR: Sky::Load(): Scotland not found
[22:35:50] Successful audio init!
[22:35:50] Loaded audio banks
[22:35:50] Initializing graphics window of size 0 x 0
[22:35:50] Attached Monitors:
[22:35:50] monitor found at: 0,0
[22:35:51] GFX_Initialize: GL_version = 4.6.0 NVIDIA 537.42
[22:35:51]                 GL_vendor = NVIDIA Corporation
[22:35:51]                 GL_render = NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2
[22:35:51] Checking Extensions
[22:35:51] GFX_KHR_debug
[22:35:51] GFX_ARB_framebuffer_object
[22:35:51] GFX_ARB_buffer_storage
[22:35:51] GFX_ARB_clip_control
[22:35:51] [GFX]: Compatability profile
[22:35:51] [GFX]: GFX_Tier 0
[22:35:51] Screen reported DPI: 96 physical DPI: 137 Scale: 1.00
[22:35:51] Calculating Graphics Score
[22:35:51] GFX: Found a vendor/model match for RTX 2060
[22:35:51] Initializing Render Targets
[22:35:51] Initializing Texture Systems
[22:35:51] [GFX]: loading shader Blur[0][0].4
[22:35:51] FILE : Loaded Vertex Shader asset shaders/Final/Blur.vsh
[22:35:51] FILE : Loaded Pixel Shader asset shaders/Final/Blur.psh
[22:35:51] Calling initialize_zwift_network()
[22:35:51] [INFO] CNL 3.38.1
[22:35:51] [INFO] Machine Id: 1-595ee1a5-7e7c-4265-84da-d9ad8f51fcec
[22:35:51] Suceeded initializing graphics
[22:35:51] [GFX]: loading shader GFXDRAW_NoTexture[0][0].4
[22:35:51] FILE : Loaded Vertex Shader asset shaders/Final/GFXDRAW_NoTexture.vsh
[22:35:51] FILE : Loaded Pixel Shader asset shaders/Final/GFXDRAW_NoTexture.psh
[22:35:51] [GFX]: loading shader GFXDRAW_Textured[0][0].4
[22:35:51] FILE : Loaded Vertex Shader asset shaders/Final/GFXDRAW_Textured.vsh
[22:35:51] FILE : Loaded Pixel Shader asset shaders/Final/GFXDRAW_Textured.psh
[22:35:51] [GFX]: loading shader GFXDRAW_Textured_Simple[0][0].4
[22:35:51] FILE : Loaded Vertex Shader asset shaders/Final/GFXDRAW_Textured_Simple.vsh
[22:35:51] FILE : Loaded Pixel Shader asset shaders/Final/GFXDRAW_Textured_Simple.psh
[22:35:51] [GFX]: loading shader GFXDRAW_Textured_GammaCorrect[0][0].4
[22:35:51] FILE : Loaded Vertex Shader asset shaders/Final/GFXDRAW_Textured_GammaCorrect.vsh
[22:35:51] FILE : Loaded Pixel Shader asset shaders/Final/GFXDRAW_Textured_GammaCorrect.psh
[22:35:51] [GFX]: loading shader GFXDRAW_sRGB_GLES[0][0].4
[22:35:51] FILE : Loaded Vertex Shader asset shaders/Final/GFXDRAW_sRGB_GLES.vsh
[22:35:51] FILE : Loaded Pixel Shader asset shaders/Final/GFXDRAW_sRGB_GLES.psh
[22:35:51] DEBUG LEVEL: Open assets/fonts/font.wad in file 0xd774ec70
[22:35:51] Loading WAD file 'assets/fonts/font.wad' with file.
[22:35:51] DEBUG LEVEL: Close file 0xd774ec70
[22:35:51] [GFX]: loading shader GFXDRAW_FontW[0][0].4
[22:35:51] FILE : Loaded Vertex Shader asset shaders/Final/GFXDRAW_FontW.vsh
[22:35:51] FILE : Loaded Pixel Shader asset shaders/Final/GFXDRAW_FontW.psh
[22:35:51] Using ultra graphics profile
[22:35:51] > res 1920x1080(0x)
[22:35:51] Changed resolution to 1920 x 1080  ( NO MSAA )
[22:35:51] > sres 2048x2048
[22:35:51] Changed shadow resolution to 2048 x 2048
[22:35:51] > set gSSAO=1
[22:35:51] > set gFXAA=1
[22:35:51] OpenGL 4.6.0 NVIDIA 537.42 initialized
[22:35:51] Graphics Vendor: NVIDIA Corporation
[22:35:51] Graphics Renderer: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2
[22:35:51] RAM: 32660GB
[22:35:51] CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
[22:35:51] ANT  : ANT USB receiver NOT found
[22:35:51] DEBUG LEVEL: Open assets/UI/Achievements/goals.wad in file 0xd774ec70
[22:35:51] Loading WAD file 'assets/UI/Achievements/goals.wad' with file.
[22:35:51] DEBUG LEVEL: Open assets/UI/Achievements/achievements.wad in file 0xd774ec70
[22:35:51] Loading WAD file 'assets/UI/Achievements/achievements.wad' with file.
[22:35:52] DEBUG LEVEL: Close file 0xd774ec70
[22:35:52] Registered segment 1 with hash id 888000
[22:35:52] Registered segment 2 with hash id 888001
[22:35:52] Registered segment 3 with hash id 888002
[22:35:52] Registered segment 4 with hash id 888003
[22:35:52] Registered segment 5 with hash id 888004
[22:35:52] [GAME]: Initialize
[22:35:52] Downloader: "MapSchedule_v2.xml" downloaded successfully (manifest checksum not provided, i.e. -1).
[22:35:52] Downloader::Update m_filesCompleted.push_back path=D:/Documents/Zwift/MapSchedule_v2.xml success=1
[22:35:52] Game::GAME_onFinishedDownloadingMapSchedule filename=MapSchedule_v2.xml err=0 state: m_filesPending: <> m_filesCurrent: <> m_filesCompleted: <MapSchedule_v2.xml>
[22:35:52] Downloader::ForgetCompleted path=MapSchedule_v2.xml
[22:35:52] [GFX]: loading shader GFXDRAW_Textured_ExtAlpha[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/GFXDRAW_Textured_ExtAlpha.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/GFXDRAW_Textured_ExtAlpha.psh
[22:35:52] [GFX]: loading shader GaussianBlur[0][0].4
[22:35:52] [GFX]: loading shader GaussianBlur[0][0].4 failed!
[22:35:52] [GFX]: loading shader SimpleShader[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/SimpleShader.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/SimpleShader.psh
[22:35:52] [GFX]: loading shader gde_nolighting[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/gde_nolighting.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/gde_nolighting.psh
[22:35:52] [GFX]: loading shader shadowmap[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/shadowmap.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/shadowmap.psh
[22:35:52] [GFX]: loading shader shadowmap_instanced[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/shadowmap_instanced.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/shadowmap_instanced.psh
[22:35:52] [GFX]: loading shader shadowmapHair[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/shadowmapHair.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/shadowmapHair.psh
[22:35:52] [GFX]: loading shader Glossy_shadowmapped[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/Glossy_shadowmapped.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/Glossy_shadowmapped.psh
[22:35:52] [GFX]: loading shader Road[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/Road.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/Road.psh
[22:35:52] [GFX]: loading shader portalRoadSFX[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/portalRoadSFX.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/portalRoadSFX.psh
[22:35:52] [GFX]: loading shader RoadAccessory[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/RoadAccessory.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/RoadAccessory.psh
[22:35:52] [GFX]: loading shader RoadWet[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/RoadWet.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/RoadWet.psh
[22:35:52] [GFX]: loading shader RoadAccessoryWet[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/RoadAccessoryWet.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/RoadAccessoryWet.psh
[22:35:52] [GFX]: loading shader HeatHaze[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/HeatHaze.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/HeatHaze.psh
[22:35:52] [GFX]: loading shader CausticPass[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/CausticPass.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/CausticPass.psh
[22:35:52] [GFX]: loading shader crepuscular[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/crepuscular.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/crepuscular.psh
[22:35:52] [GFX]: loading shader beam[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/beam.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/beam.psh
[22:35:52] [GFX]: loading shader beam_inside[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/beam_inside.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/beam_inside.psh
[22:35:52] [GFX]: loading shader defaultWorld[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/defaultWorld.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/defaultWorld.psh
[22:35:52] [GFX]: loading shader defaultWorldAO[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/defaultWorldAO.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/defaultWorldAO.psh
[22:35:52] [GFX]: loading shader defaultWorldBillboard[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/defaultWorldBillboard.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/defaultWorldBillboard.psh
[22:35:52] [GFX]: loading shader defaultWorldSimple[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/defaultWorldSimple.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/defaultWorldSimple.psh
[22:35:52] [GFX]: loading shader Hologram[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/Hologram.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/Hologram.psh
[22:35:52] [GFX]: loading shader RainbowHologram[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/RainbowHologram.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/RainbowHologram.psh
[22:35:52] [GFX]: loading shader Glossy_locked[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/Glossy_locked.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/Glossy_locked.psh
[22:35:52] [GFX]: loading shader londonTerrainShader[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/londonTerrainShader.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/londonTerrainShader.psh
[22:35:52] [GFX]: loading shader londonTerrainShader_HeightMap[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/londonTerrainShader_HeightMap.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/londonTerrainShader_HeightMap.psh
[22:35:52] [GFX]: loading shader franceTerrainShader[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/franceTerrainShader.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/franceTerrainShader.psh
[22:35:52] [GFX]: loading shader franceTerrainShader_HeightMap[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/franceTerrainShader_HeightMap.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/franceTerrainShader_HeightMap.psh
[22:35:52] [GFX]: loading shader BasicTerrain[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/BasicTerrain.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/BasicTerrain.psh
[22:35:52] [GFX]: loading shader BasicTerrain_HeightMap[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/BasicTerrain_HeightMap.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/BasicTerrain_HeightMap.psh
[22:35:52] [GFX]: loading shader BasicTerrainNoSnow[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/BasicTerrainNoSnow.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/BasicTerrainNoSnow.psh
[22:35:52] [GFX]: loading shader BasicTerrainNoSnow_HeightMap[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/BasicTerrainNoSnow_HeightMap.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/BasicTerrainNoSnow_HeightMap.psh
[22:35:52] [GFX]: loading shader BasicTerrainWatopiaDesert[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/BasicTerrainWatopiaDesert.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/BasicTerrainWatopiaDesert.psh
[22:35:52] [GFX]: loading shader BasicTerrainWatopiaDesert_HeightMap[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/BasicTerrainWatopiaDesert_HeightMap.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/BasicTerrainWatopiaDesert_HeightMap.psh
[22:35:52] [GFX]: loading shader innsbruckTerrainShader_HeightMap[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/innsbruckTerrainShader_HeightMap.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/innsbruckTerrainShader_HeightMap.psh
[22:35:52] [GFX]: loading shader innsbruckTerrainShader[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/innsbruckTerrainShader.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/innsbruckTerrainShader.psh
[22:35:52] [GFX]: loading shader bolognaTerrainShader_HeightMap[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/bolognaTerrainShader_HeightMap.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/bolognaTerrainShader_HeightMap.psh
[22:35:52] [GFX]: loading shader bolognaTerrainShader[0][0].4
[22:35:52] FILE : Loaded Vertex Shader asset shaders/Final/bolognaTerrainShader.vsh
[22:35:52] FILE : Loaded Pixel Shader asset shaders/Final/bolognaTerrainShader.psh
(snip)
[22:36:10] LoadWorkout failed to load.
[22:36:10] Failed workout path: Workouts/workouts2.categories
[22:36:10] DEBUG LEVEL: Open assets\Workouts\workouts.wad in file 0xd774ec70
[22:36:10] Loading WAD file 'assets\Workouts\workouts.wad' with file.
[22:36:10] DEBUG LEVEL: Close file 0xd774ec70
[22:36:10] Loaded training plan 'Fast Track Fitness' : 1518164201
[22:36:10] Loaded training plan 'Back to Fitness' : 1933759722
[22:36:10] Loaded training plan 'PRL100 2019' : -1879684214
[22:36:10] Loaded training plan 'PRL46 2019' : 1979360334
[22:36:10] Loaded training plan 'FTP Builder' : 1803127634
[22:36:10] Loaded training plan 'Active Offseason' : 2048408838
[22:36:10] Loaded training plan 'Fondo' : 635512089
[22:36:10] Loaded training plan 'Gran Fondo' : 972360468
[22:36:10] Loaded training plan 'CRIT Crusher' : 142075445
[22:36:10] Loaded training plan '3 Run 13.1' : 1200543035
[22:36:10] Loaded training plan '3 Run 13.1 Lite' : -641345532
[22:36:10] Loaded training plan '5k Record Breaker' : -260540131
[22:36:10] Loaded training plan '5k Record Breaker Lite' : -1976265984
[22:36:10] Loaded training plan 'Build Me Up' : 1160472062
[22:36:10] Loaded training plan 'Build Me Up Lite' : 147262524
[22:36:10] Loaded training plan 'TT Tune-Up' : -87367306
[22:36:10] Loaded training plan 'Cyclist to 10k' : -1390843198
[22:36:10] Loaded training plan 'Gravel Grinder' : -974492337
[22:36:10] Loaded training plan 'ZWIFT 101: Running' : 622710059
[22:36:10] Loaded training plan 'ZWIFT 101: CYCLING' : 1499915840
[22:36:10] Loaded training plan 'Watopia Half-Marathon' : 945347367
[22:36:10] Loaded training plan 'Multisport Mixer' : 1064629577
[22:36:10] Loaded training plan 'Zwift Special Access: Coast Ride' : 884034614
[22:36:10] Loaded training plan 'High-Mileage Half' : 23939648
[22:36:10] Loaded training plan 'Los Angeles Marathon: Phase 1' : -26592924
[22:36:10] Loaded training plan 'Los Angeles Marathon: Phase 2' : -1177926732
[22:36:10] Loaded training plan 'ZWIFT 201: Your First 5K' : -1334990693
[22:36:10] Loaded training plan 'Dirt Destroyer' : 359714946
[22:36:10] Loaded training plan 'Pebble Pounder' : -321384698
[22:36:10] Loaded training plan 'Singletrack Slayer' : -20752954
[22:36:10] Loaded training plan 'Zwift Racing' : 160527161
[22:36:10] ---CloudSync::FindCloudFileID workouts.files
[22:36:10] ---CloudSync::FindCloudFileID gearing.files
[22:36:10] [PostLoginInit] FinishedState: Success
[22:36:10] [ZWATCHDOG]: GameFlowState Pairing
[22:36:10] GPU DEPRECATION INCOMING VENDOR, RENDERER: NVIDIA CorporationNVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2
[22:36:10] INFO LEVEL: Queuing high volume analytics event: Deprecated GPU Message
[22:36:10] PairingScreen CTOR (PBE) start
[22:36:10] BLE initialization
[22:37:04] [INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
I am having the same issues. If I am lucky and get to the screen that allows me to choose my sources, I can say Skip and it will take me to the main screen. But anytime I attempt to pair, it locks up or gets very slow again.
I created a local user, and Zwift worked well.
However, I don’t still know why it doesn’t work in the main user.
