Zwift not responding mid session
Dear all,
zwift is not responding mid session. (well in the last bits of the sessions which makes it extra annoying)
Waiting doesn’t help 15+ minutes. It happens with short and long sessions.
PC specs:
Intel i7 Microsoft Surface Pro 16GB.
Zwift is fully up to date and the trainer is too.
Below the last 10 minutes of the last session:
===================Session 1 ===================
[18:35:15] FE-C SIM GRADE 0.000
[18:35:15] ANT : Transfer Completed.
[18:35:15] ANT : FET grade set successfully
[18:35:16] FE-C SIM GRADE 0.000
[18:35:16] ANT : Transfer Failed.
[18:35:16] ANT : ----------------------
[18:35:16] ANT : FET Transmission failed. m_CurrentMode = 4
[18:35:16] ANT : Rx Fail on channel 2
[18:35:17] ANT : Rx Fail on channel 2
[18:35:17] FE-C SIM GRADE 0.000
[18:35:17] FPS 59, 47765, 11835, 471706
[18:35:17] ANT : Rx Fail on channel 1
[18:35:17] ANT : Transfer Completed.
[18:35:17] ANT : FET grade set successfully
[18:35:18] ANT : Rx Fail on channel 2
[18:35:18] FE-C SIM GRADE 0.000
[18:35:18] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[18:35:18] ANT : Transfer Completed.
[18:35:18] ANT : FET grade set successfully
[18:35:19] FE-C SIM GRADE 0.000
[18:35:19] ANT : Transfer Completed.
[18:35:19] ANT : FET grade set successfully
[18:35:19] ANT : Rx Fail on channel 1
[18:35:20] FE-C SIM GRADE 0.000
[18:35:20] ANT : Transfer Completed.
[18:35:20] ANT : FET grade set successfully
[18:35:21] FE-C SIM GRADE 0.000
[18:35:21] ANT : Transfer Completed.
[18:35:21] ANT : FET grade set successfully
[18:35:22] Starting critical power curve search job (247644740) mTimeStamp = 1614.23914 m_lastSearchTime = 1614.23914 calculating=false
[18:35:22] FE-C SIM GRADE 0.000
[18:35:22] ANT : Transfer Completed.
[18:35:22] ANT : FET grade set successfully
[18:35:22] ANT : Rx Fail on channel 1
[18:35:23] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.2.13:21587
[18:35:23] FE-C SIM GRADE 0.000
[18:35:23] ANT : Transfer Completed.
[18:35:23] ANT : FET grade set successfully
[18:35:24] FE-C SIM GRADE 0.000
[18:35:24] ANT : Transfer Completed.
[18:35:24] ANT : FET grade set successfully
[18:35:24] ANT : Rx Fail on channel 1
[18:35:25] FE-C SIM GRADE 0.000
[18:35:25] ANT : Transfer Completed.
[18:35:25] ANT : FET grade set successfully
[18:35:25] FPS 65, 51473, 11837, 464901
[18:35:25] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘No connection could be made because the target machine actively refused it.’ (10061)
[18:35:26] FE-C SIM GRADE 0.000
[18:35:26] ANT : Transfer Completed.
[18:35:26] ANT : FET grade set successfully
[18:35:26] FE-C 240 received
[18:35:26] TimingArch: () passed checkpoint 0
[18:35:27] FE-C SIM GRADE 0.000
[18:35:27] ANT : Transfer Completed.
[18:35:27] ANT : FET grade set successfully
[18:35:28] FE-C SIM GRADE 0.000
[18:35:28] ANT : Transfer Completed.
[18:35:28] ANT : FET grade set successfully
[18:35:29] ANT : Rx Fail on channel 1
[18:35:29] FE-C SIM GRADE 0.000
[18:35:29] ANT : Transfer Completed.
[18:35:29] ANT : FET grade set successfully
[18:35:30] ANT : Rx Fail on channel 1
[18:35:30] FE-C SIM GRADE 0.000
[18:35:30] ANT : Transfer Completed.
[18:35:30] ANT : FET grade set successfully
[18:35:31] ANT : Rx Fail on channel 1
[18:35:31] FE-C SIM GRADE 0.000
[18:35:31] ANT : Rx Fail on channel 2
[18:35:31] ANT : Transfer Completed.
[18:35:31] ANT : FET grade set successfully
[18:35:32] ANT : Rx Fail on channel 1
[18:35:32] Starting critical power curve search job (247654765) mTimeStamp = 1624.26758 m_lastSearchTime = 1624.26758 calculating=false
[18:35:32] FE-C SIM GRADE 0.000
[18:35:32] ANT : Transfer Completed.
[18:35:32] ANT : FET grade set successfully
[18:35:33] FE-C SIM GRADE 0.000
[18:35:33] ANT : Transfer Completed.
[18:35:33] ANT : FET grade set successfully
[18:35:33] FPS 63, 52755, 11842, 457433
[18:35:33] ANT : Rx Fail on channel 1
[18:35:34] FE-C SIM GRADE 0.000
[18:35:34] ANT : Transfer Completed.
[18:35:34] ANT : FET grade set successfully
[18:35:34] ANT : dID 1129213 MFG 89 Model 2900
[18:35:35] ANT : Rx Fail on channel 1
[18:35:35] FE-C SIM GRADE 0.000
[18:35:35] ANT : Transfer Completed.
[18:35:35] ANT : FET grade set successfully
[18:35:36] FE-C SIM GRADE 0.000
[18:35:36] ANT : Transfer Completed.
[18:35:36] ANT : FET grade set successfully
[18:35:37] ANT : Rx Fail on channel 1
[18:35:37] FE-C SIM GRADE 0.000
[18:35:37] ANT : Transfer Completed.
[18:35:37] ANT : FET grade set successfully
[18:35:38] FE-C SIM GRADE 0.000
[18:35:38] ANT : Transfer Completed.
[18:35:38] ANT : FET grade set successfully
[18:35:39] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.2.13:21587
[18:35:39] NETCLIENT:[INFO] Sending telemetry…
[18:35:39] FE-C SIM GRADE 0.000
[18:35:39] ANT : Transfer Failed.
[18:35:39] ANT : ----------------------
[18:35:39] ANT : FET Transmission failed. m_CurrentMode = 4
[18:35:39] NETCLIENT:[INFO] UDP metrics {StC Rx: 1220, Rx error: 0, CtS Tx: 300, Tx error: 0}
[18:35:39] ANT : Rx Fail on channel 1
[18:35:40] NETCLIENT:[INFO] Telemetry successfully sent
[18:35:40] FE-C SIM GRADE 0.000
[18:35:40] ANT : Transfer Completed.
[18:35:40] ANT : FET grade set successfully
[18:35:41] FE-C SIM GRADE 0.000
[18:35:41] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘No connection could be made because the target machine actively refused it.’ (10061)
[18:35:41] FPS 66, 49464, 11845, 450417
[18:35:41] ANT : Transfer Completed.
[18:35:41] ANT : FET grade set successfully
[18:35:42] Starting critical power curve search job (247664800) mTimeStamp = 1634.30261 m_lastSearchTime = 1634.30261 calculating=false
[18:35:42] FE-C SIM GRADE 0.000
[18:35:42] ANT : Transfer Completed.
[18:35:42] ANT : FET grade set successfully
[18:35:42] ANT : Rx Fail on channel 2
[18:35:43] ANT : Rx Fail on channel 2
[18:35:43] FE-C 249 received
[18:35:43] ANT : Rx Fail on channel 1
[18:35:43] FE-C SIM GRADE 0.000
[18:35:43] ANT : Transfer Completed.
[18:35:43] ANT : FET grade set successfully
[18:35:44] FE-C SIM GRADE 0.000
[18:35:44] ANT : Transfer Completed.
[18:35:44] ANT : FET grade set successfully
[18:35:45] ANT : Rx Fail on channel 1
[18:35:45] FE-C SIM GRADE 0.000
[18:35:45] ANT : Transfer Completed.
[18:35:45] ANT : FET grade set successfully
[18:35:46] FE-C SIM GRADE 0.000
[18:35:46] ANT : Transfer Completed.
[18:35:46] ANT : FET grade set successfully
[18:35:47] ANT : Rx Fail on channel 1
[18:35:47] FE-C SIM GRADE 0.000
[18:35:47] ANT : Transfer Completed.
[18:35:47] ANT : FET grade set successfully
[18:35:48] FE-C SIM GRADE 0.000
[18:35:48] ANT : Transfer Completed.
[18:35:48] ANT : FET grade set successfully
[18:35:49] FPS 68, 43471, 11846, 445597
[18:35:49] FE-C SIM GRADE 0.000
[18:35:49] ANT : Rx Fail on channel 1
[18:35:49] ANT : Transfer Completed.
[18:35:49] ANT : FET grade set successfully
[18:35:50] FE-C SIM GRADE 0.000
[18:35:50] ANT : Transfer Completed.
[18:35:50] ANT : FET grade set successfully
[18:35:50] NETCLIENT:[INFO] World clock offset updated from -2118125147ms to -2118125146ms (+1ms)
[18:35:51] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[18:35:51] FE-C SIM GRADE -0.000
[18:35:51] ANT : Rx Fail on channel 1
[18:35:51] ANT : Transfer Completed.
[18:35:51] ANT : FET grade set successfully
[18:35:52] Starting critical power curve search job (247674821) mTimeStamp = 1644.33228 m_lastSearchTime = 1644.33228 calculating=false
[18:35:52] FE-C SIM GRADE -0.000
[18:35:52] ANT : Transfer Completed.
[18:35:52] ANT : FET grade set successfully
[18:35:53] FE-C SIM GRADE -0.000
[18:35:53] ANT : Transfer Completed.
[18:35:53] ANT : FET grade set successfully
[18:35:53] ANT : Rx Fail on channel 1
[18:35:54] FE-C SIM GRADE -0.000
[18:35:54] ANT : Transfer Completed.
[18:35:54] ANT : FET grade set successfully
[18:35:54] ANT : Rx Fail on channel 2
[18:35:55] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.2.13:21587
[18:35:55] ANT : Rx Fail on channel 2
[18:35:55] FE-C SIM GRADE -0.000
[18:35:55] ANT : Transfer Completed.
[18:35:55] ANT : FET grade set successfully
[18:35:56] FE-C SIM GRADE -0.000
[18:35:56] ANT : Transfer Completed.
[18:35:56] ANT : FET grade set successfully
[18:35:57] FPS 65, 36243, 11846, 442912
[18:35:57] FE-C SIM GRADE -0.000
[18:35:57] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘No connection could be made because the target machine actively refused it.’ (10061)
[18:35:57] ANT : Transfer Completed.
[18:35:57] ANT : FET grade set successfully
[18:35:58] ANT : Rx Fail on channel 1
[18:35:58] FE-C SIM GRADE -0.000
[18:35:58] ANT : Transfer Completed.
[18:35:58] ANT : FET grade set successfully
[18:35:59] ANT : Rx Fail on channel 1
[18:35:59] FE-C SIM GRADE -0.000
[18:35:59] FE-C 240 received
[18:35:59] ANT : Transfer Completed.
[18:35:59] ANT : FET grade set successfully
[18:36:00] FE-C SIM GRADE -0.000
[18:36:00] ANT : Transfer Completed.
[18:36:00] ANT : FET grade set successfully
[18:36:00] ANT : Rx Fail on channel 1
[18:36:01] FE-C SIM GRADE -0.000
[18:36:01] ANT : Transfer Completed.
[18:36:01] ANT : FET grade set successfully
[18:36:02] Starting critical power curve search job (247684847) mTimeStamp = 1654.36267 m_lastSearchTime = 1654.36267 calculating=false
[18:36:02] FE-C SIM GRADE -0.000
[18:36:02] ANT : Transfer Completed.
[18:36:02] ANT : FET grade set successfully
[18:36:03] FE-C SIM GRADE -0.000
[18:36:03] ANT : Rx Fail on channel 1
[18:36:03] ANT : Transfer Completed.
[18:36:03] ANT : FET grade set successfully
[18:36:04] FE-C SIM GRADE 0.000
[18:36:04] ANT : Transfer Completed.
[18:36:04] ANT : FET grade set successfully
[18:36:05] FPS 69, 30193, 11845, 438538
[18:36:05] FE-C SIM GRADE 0.000
[18:36:05] ANT : Transfer Completed.
[18:36:05] ANT : FET grade set successfully
[18:36:06] ANT : Rx Fail on channel 1
[18:36:06] FE-C SIM GRADE -0.000
[18:36:06] ANT : Transfer Completed.
[18:36:06] ANT : FET grade set successfully
[18:36:07] FE-C SIM GRADE -0.000
[18:36:07] ANT : dID 1129213 MFG 89 Model 2900
[18:36:07] ANT : Transfer Completed.
[18:36:07] ANT : FET grade set successfully
[18:36:08] ANT : Rx Fail on channel 2
[18:36:08] FE-C SIM GRADE -0.000
[18:36:08] ANT : Transfer Completed.
[18:36:08] ANT : FET grade set successfully
[18:36:12] ANT : Rx Fail on channel 1
[18:36:13] ANT : Rx Fail on channel 1
[18:36:14] ANT : Rx Fail on channel 1
[18:36:16] FE-C 240 received
[18:36:16] ANT : Rx Fail on channel 1
[18:36:16] FE-C 249 received
[18:36:17] ANT : Rx Fail on channel 1
[18:36:19] ANT : Rx Fail on channel 2
[18:36:19] ANT : Rx Fail on channel 1
[18:36:20] ANT : Rx Fail on channel 2
[18:36:20] ANT : Rx Fail on channel 1
[18:36:24] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[18:36:25] ANT : Rx Fail on channel 1
[18:36:39] NETCLIENT:[INFO] Sending telemetry…
[18:36:39] NETCLIENT:[INFO] Telemetry successfully sent
[18:36:39] NETCLIENT:[INFO] UDP metrics {StC Rx: 1149, Rx error: 0, CtS Tx: 146, Tx error: 0}
[18:36:49] NETCLIENT:[WARN] UDP connection timeout (1 so far), reconnection attempt 1
[18:36:49] NETCLIENT:[INFO] Connecting to UDP server…
[18:36:59] NETCLIENT:[WARN] UDP connection timeout (2 so far), reconnection attempt 2
[18:36:59] NETCLIENT:[INFO] Connecting to UDP server…
[18:37:09] NETCLIENT:[WARN] UDP connection timeout (3 so far), reconnection attempt 3
[18:37:09] NETCLIENT:[INFO] Connecting to UDP server…
[18:37:39] NETCLIENT:[WARN] UDP connection timeout (4 so far), reconnection attempt 4
[18:37:39] NETCLIENT:[INFO] Connecting to UDP server…
[18:37:39] NETCLIENT:[INFO] Sending telemetry…
[18:37:39] NETCLIENT:[INFO] Telemetry successfully sent
[18:37:39] NETCLIENT:[INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
[18:38:09] NETCLIENT:[WARN] UDP connection timeout (5 so far), reconnection attempt 5
[18:38:09] NETCLIENT:[INFO] Connecting to UDP server…
[18:38:39] NETCLIENT:[WARN] UDP connection timeout (6 so far), reconnection attempt 6
[18:38:39] NETCLIENT:[INFO] Connecting to UDP server…
[18:38:39] NETCLIENT:[INFO] Sending telemetry…
[18:38:39] NETCLIENT:[INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
[18:38:40] NETCLIENT:[INFO] Telemetry successfully sent
[18:39:09] NETCLIENT:[WARN] UDP connection timeout (7 so far), reconnection attempt 7
[18:39:09] NETCLIENT:[INFO] Connecting to UDP server…
[18:39:39] NETCLIENT:[WARN] UDP connection timeout (8 so far), reconnection attempt 8
[18:39:39] NETCLIENT:[INFO] Connecting to UDP server…
[18:39:39] NETCLIENT:[INFO] Sending telemetry…
[18:39:39] NETCLIENT:[INFO] Telemetry successfully sent
[18:39:39] NETCLIENT:[INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
[18:40:09] NETCLIENT:[WARN] UDP connection timeout (9 so far), reconnection attempt 9
[18:40:09] NETCLIENT:[INFO] Connecting to UDP server…
[18:40:39] NETCLIENT:[WARN] UDP connection timeout (10 so far), reconnection attempt 10
[18:40:39] NETCLIENT:[INFO] Connecting to UDP server…
[18:40:39] NETCLIENT:[INFO] Sending telemetry…
[18:40:39] NETCLIENT:[INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
[18:40:40] NETCLIENT:[INFO] Telemetry successfully sent
[18:41:09] NETCLIENT:[WARN] UDP connection timeout (11 so far), reconnection attempt 11
[18:41:09] NETCLIENT:[INFO] Connecting to UDP server…
[18:41:39] NETCLIENT:[WARN] UDP connection timeout (12 so far), reconnection attempt 12
[18:41:39] NETCLIENT:[INFO] Connecting to UDP server…
[18:41:39] NETCLIENT:[INFO] Sending telemetry…
[18:41:39] NETCLIENT:[INFO] Telemetry successfully sent
[18:41:39] NETCLIENT:[INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
[18:42:09] NETCLIENT:[WARN] UDP connection timeout (13 so far), reconnection attempt 13
[18:42:09] NETCLIENT:[INFO] Connecting to UDP server…
[18:42:39] NETCLIENT:[WARN] UDP connection timeout (14 so far), reconnection attempt 14
[18:42:39] NETCLIENT:[INFO] Connecting to UDP server…
[18:42:39] NETCLIENT:[INFO] Sending telemetry…
[18:42:39] NETCLIENT:[INFO] Telemetry successfully sent
[18:42:39] NETCLIENT:[INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
[18:43:17] NETCLIENT:[WARN] UDP connection timeout (15 so far), reconnection attempt 15
[18:43:17] NETCLIENT:[INFO] Connecting to UDP server…
second log:
================== Second Session =================
[12:46:33] FPS 54, -9073, 14993, 86709
[12:46:34] FE-C SIM GRADE 0.006
[12:46:34] ANT : Transfer Completed.
[12:46:34] ANT : FET grade set successfully
[12:46:35] ANT : Rx Fail on channel 1
[12:46:35] FE-C SIM GRADE 0.006
[12:46:35] ANT : Transfer Completed.
[12:46:35] ANT : FET grade set successfully
[12:46:35] ANT : Rx Fail on channel 2
[12:46:36] ANT : Rx Fail on channel 2
[12:46:36] FE-C SIM GRADE 0.006
[12:46:36] FE-C 240 received
[12:46:36] ANT : Transfer Completed.
[12:46:36] ANT : FET grade set successfully
[12:46:37] NETCLIENT:[WARN] Auxiliary Controller failed to shut down tcp socket: ‘A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.’ (10057)
[12:46:37] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘The I/O operation has been aborted because of either a thread exit or an application request.’ (995)
[12:46:40] ANT : Rx Fail on channel 1
[12:46:42] ANT : Rx Fail on channel 1
[12:46:43] ANT : Rx Fail on channel 1
[12:46:44] ANT : Rx Fail on channel 1
[12:46:44] ANT : dID 1129213 MFG 89 Model 2900
[12:46:45] ANT : Rx Fail on channel 1
[12:46:48] ANT : Rx Fail on channel 2
[12:46:49] ANT : Rx Fail on channel 2
[12:46:52] ANT : Rx Fail on channel 1
[12:46:52] FE-C 240 received
[12:46:53] FE-C 249 received
[12:47:00] ANT : Rx Fail on channel 2
[12:47:01] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:47:01] ANT : Rx Fail on channel 2
[12:47:02] ANT : Rx Fail on channel 2
[12:47:03] ANT : Rx Fail on channel 1
[12:47:04] ANT : Rx Fail on channel 1
[12:47:08] ANT : Rx Fail on channel 2
[12:47:09] FE-C 240 received
[12:47:09] ANT : Rx Fail on channel 1
[12:47:12] ANT : Rx Fail on channel 1
[12:47:14] ANT : Rx Fail on channel 1
[12:47:14] NETCLIENT:[INFO] Sending telemetry…
[12:47:15] NETCLIENT:[INFO] UDP metrics {StC Rx: 813, Rx error: 0, CtS Tx: 107, Tx error: 0}
[12:47:15] NETCLIENT:[INFO] Telemetry successfully sent
[12:47:15] ANT : Rx Fail on channel 2
[12:47:17] NETCLIENT:[WARN] UDP connection timeout (2 so far), reconnection attempt 2
[12:47:17] NETCLIENT:[INFO] Connecting to UDP server…
[12:47:17] ANT : dID 1129213 MFG 89 Model 2900
[12:47:19] ANT : Rx Fail on channel 1
[12:47:21] ANT : Rx Fail on channel 1
[12:47:22] ANT : Rx Fail on channel 1
[12:47:23] ANT : Rx Fail on channel 2
[12:47:25] ANT : Rx Fail on channel 1
[12:47:25] FE-C 240 received
[12:47:26] FE-C 249 received
[12:47:27] NETCLIENT:[WARN] UDP connection timeout (3 so far), reconnection attempt 3
[12:47:27] NETCLIENT:[INFO] Connecting to UDP server…
[12:47:27] ANT : Rx Fail on channel 2
[12:47:28] ANT : Rx Fail on channel 2
[12:47:33] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:47:34] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:47:35] ANT : Rx Fail on channel 1
[12:47:36] ANT : Rx Fail on channel 1
[12:47:38] ANT : Rx Fail on channel 1
[12:47:40] ANT : Rx Fail on channel 1
[12:47:42] ANT : Rx Fail on channel 2
[12:47:44] ANT : Rx Fail on channel 1
[12:47:45] ANT : Rx Fail on channel 1
[12:47:48] ANT : Rx Fail on channel 1
[12:47:48] ANT : Rx Fail on channel 2
[12:47:50] ANT : dID 1129213 MFG 89 Model 2900
[12:47:50] ANT : Rx Fail on channel 1
[12:47:53] ANT : Rx Fail on channel 2
[12:47:54] ANT : Rx Fail on channel 2
[12:47:54] ANT : Rx Fail on channel 1
[12:47:56] ANT : Rx Fail on channel 1
[12:47:57] NETCLIENT:[WARN] UDP connection timeout (4 so far), reconnection attempt 4
[12:47:57] NETCLIENT:[INFO] Connecting to UDP server…
[12:47:58] FE-C 240 received
[12:47:59] FE-C 249 received
[12:47:59] ANT : Rx Fail on channel 1
[12:48:01] ANT : Rx Fail on channel 1
[12:48:06] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:48:07] ANT : Rx Fail on channel 1
[12:48:07] ANT : Rx Fail on channel 2
[12:48:11] ANT : Rx Fail on channel 1
[12:48:13] ANT : Rx Fail on channel 1
[12:48:14] ANT : Rx Fail on channel 1
[12:48:14] NETCLIENT:[INFO] Sending telemetry…
[12:48:15] NETCLIENT:[INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
[12:48:15] FE-C 240 received
[12:48:15] NETCLIENT:[INFO] Telemetry successfully sent
[12:48:16] ANT : Rx Fail on channel 1
[12:48:18] ANT : Rx Fail on channel 1
[12:48:19] ANT : Rx Fail on channel 1
[12:48:20] ANT : Rx Fail on channel 2
[12:48:20] ANT : Rx Fail on channel 1
[12:48:21] ANT : Rx Fail on channel 1
[12:48:22] ANT : Rx Fail on channel 1
[12:48:23] ANT : Rx Fail on channel 1
[12:48:23] ANT : dID 1129213 MFG 89 Model 2900
[12:48:24] ANT : Rx Fail on channel 1
[12:48:25] ANT : Rx Fail on channel 1
[12:48:26] ANT : Rx Fail on channel 1
[12:48:27] NETCLIENT:[WARN] UDP connection timeout (5 so far), reconnection attempt 5
[12:48:27] NETCLIENT:[INFO] Connecting to UDP server…
[12:48:27] ANT : Rx Fail on channel 1
[12:48:28] ANT : Rx Fail on channel 1
[12:48:29] ANT : Rx Fail on channel 1
[12:48:30] ANT : Rx Fail on channel 2
[12:48:30] ANT : Rx Fail on channel 1
[12:48:31] FE-C 240 received
[12:48:32] FE-C 249 received
[12:48:32] ANT : Rx Fail on channel 1
[12:48:33] ANT : Rx Fail on channel 1
[12:48:34] ANT : Rx Fail on channel 1
[12:48:35] ANT : Rx Fail on channel 1
[12:48:35] ANT : Rx Fail on channel 2
[12:48:36] ANT : Rx Fail on channel 2
[12:48:36] ANT : Rx Fail on channel 1
[12:48:37] ANT : Rx Fail on channel 1
[12:48:39] ANT : Rx Fail on channel 1
[12:48:39] ANT : Rx Fail on channel 2
[12:48:39] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:48:40] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:48:40] ANT : Rx Fail on channel 1
[12:48:41] ANT : Rx Fail on channel 1
[12:48:42] ANT : Rx Fail on channel 1
[12:48:44] ANT : Rx Fail on channel 1
[12:48:47] ANT : Rx Fail on channel 1
[12:48:48] FE-C 240 received
[12:48:48] ANT : Rx Fail on channel 1
[12:48:49] ANT : Rx Fail on channel 1
[12:48:49] ANT : Rx Fail on channel 2
[12:48:50] ANT : Rx Fail on channel 2
[12:48:56] ANT : dID 1129213 MFG 89 Model 2900
[12:48:57] NETCLIENT:[WARN] UDP connection timeout (6 so far), reconnection attempt 6
[12:48:57] NETCLIENT:[INFO] Connecting to UDP server…
[12:48:57] ANT : Rx Fail on channel 1
[12:48:58] ANT : Rx Fail on channel 1
[12:48:59] ANT : Rx Fail on channel 1
[12:49:00] ANT : Rx Fail on channel 1
[12:49:00] ANT : Rx Fail on channel 2
[12:49:01] ANT : Rx Fail on channel 1
[12:49:02] ANT : Rx Fail on channel 1
[12:49:04] FE-C 240 received
[12:49:05] FE-C 249 received
[12:49:05] ANT : Rx Fail on channel 1
[12:49:12] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:49:13] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:49:14] ANT : Rx Fail on channel 2
[12:49:14] NETCLIENT:[INFO] Sending telemetry…
[12:49:15] NETCLIENT:[INFO] Telemetry successfully sent
[12:49:15] NETCLIENT:[INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
[12:49:16] ANT : Rx Fail on channel 1
[12:49:21] ANT : Rx Fail on channel 1
[12:49:21] FE-C 240 received
[12:49:22] ANT : Rx Fail on channel 1
[12:49:27] ANT : Rx Fail on channel 1
[12:49:27] NETCLIENT:[WARN] UDP connection timeout (7 so far), reconnection attempt 7
[12:49:27] NETCLIENT:[INFO] Connecting to UDP server…
[12:49:28] ANT : Rx Fail on channel 2
[12:49:28] ANT : Rx Fail on channel 1
[12:49:29] ANT : Rx Fail on channel 2
[12:49:29] ANT : dID 1129213 MFG 89 Model 2900
[12:49:30] ANT : Rx Fail on channel 1
[12:49:32] ANT : Rx Fail on channel 1
[12:49:33] ANT : Rx Fail on channel 1
[12:49:35] ANT : Rx Fail on channel 1
[12:49:36] ANT : Rx Fail on channel 1
[12:49:37] FE-C 240 received
[12:49:38] FE-C 249 received
[12:49:39] ANT : Rx Fail on channel 1
[12:49:41] ANT : Rx Fail on channel 2
[12:49:41] ANT : Rx Fail on channel 1
[12:49:42] ANT : Rx Fail on channel 1
[12:49:44] ANT : Rx Fail on channel 1
[12:49:45] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:49:46] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:49:46] ANT : Rx Fail on channel 1
[12:49:50] ANT : Rx Fail on channel 2
[12:49:51] ANT : Rx Fail on channel 1
[12:49:54] FE-C 240 received
[12:49:54] ANT : Rx Fail on channel 2
[12:49:55] ANT : Rx Fail on channel 2
[12:49:56] ANT : Rx Fail on channel 1
[12:49:57] NETCLIENT:[WARN] UDP connection timeout (8 so far), reconnection attempt 8
[12:49:57] NETCLIENT:[INFO] Connecting to UDP server…
[12:50:02] ANT : dID 1129213 MFG 89 Model 2900
[12:50:02] ANT : Rx Fail on channel 1
[12:50:03] ANT : Rx Fail on channel 2
[12:50:03] ANT : Rx Fail on channel 1
[12:50:04] ANT : Rx Fail on channel 1
[12:50:06] ANT : Rx Fail on channel 1
[12:50:06] ANT : Rx Fail on channel 2
[12:50:07] ANT : Rx Fail on channel 2
[12:50:10] FE-C 240 received
[12:50:11] FE-C 249 received
[12:50:14] NETCLIENT:[INFO] Sending telemetry…
[12:50:14] ANT : Rx Fail on channel 1
[12:50:15] NETCLIENT:[INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
[12:50:15] NETCLIENT:[INFO] Telemetry successfully sent
[12:50:18] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:50:19] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:50:22] ANT : Rx Fail on channel 2
[12:50:22] ANT : Rx Fail on channel 1
[12:50:24] ANT : Rx Fail on channel 1
[12:50:25] ANT : Rx Fail on channel 1
[12:50:27] NETCLIENT:[WARN] UDP connection timeout (9 so far), reconnection attempt 9
[12:50:27] NETCLIENT:[INFO] Connecting to UDP server…
[12:50:27] FE-C 240 received
[12:50:30] ANT : Rx Fail on channel 1
[12:50:31] ANT : Rx Fail on channel 2
[12:50:32] ANT : Rx Fail on channel 1
[12:50:35] ANT : Rx Fail on channel 2
[12:50:35] ANT : dID 1129213 MFG 89 Model 2900
[12:50:36] ANT : Rx Fail on channel 1
[12:50:37] ANT : Rx Fail on channel 1
[12:50:39] ANT : Rx Fail on channel 2
[12:50:43] FE-C 240 received
[12:50:44] FE-C 249 received
[12:50:46] ANT : Rx Fail on channel 1
[12:50:47] ANT : Rx Fail on channel 2
[12:50:48] ANT : Rx Fail on channel 2
[12:50:51] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:50:52] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:50:55] ANT : Rx Fail on channel 2
[12:50:56] ANT : Rx Fail on channel 1
[12:50:57] NETCLIENT:[WARN] UDP connection timeout (10 so far), reconnection attempt 10
[12:50:57] NETCLIENT:[INFO] Connecting to UDP server…
[12:50:59] ANT : Rx Fail on channel 1
[12:51:00] FE-C 240 received
[12:51:01] ANT : Rx Fail on channel 2
[12:51:02] ANT : Rx Fail on channel 2
[12:51:08] ANT : Rx Fail on channel 1
[12:51:08] ANT : dID 1129213 MFG 89 Model 2900
[12:51:11] ANT : Rx Fail on channel 1
[12:51:13] ANT : Rx Fail on channel 2
[12:51:14] ANT : Rx Fail on channel 1
[12:51:14] NETCLIENT:[INFO] Sending telemetry…
[12:51:15] NETCLIENT:[INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
[12:51:15] NETCLIENT:[INFO] Telemetry successfully sent
[12:51:16] ANT : Rx Fail on channel 1
[12:51:16] FE-C 240 received
[12:51:17] FE-C 249 received
[12:51:19] ANT : Rx Fail on channel 1
[12:51:23] ANT : Rx Fail on channel 1
[12:51:24] ANT : Rx Fail on channel 1
[12:51:24] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:51:25] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:51:25] ANT : Rx Fail on channel 1
[12:51:25] ANT : Rx Fail on channel 2
[12:51:27] NETCLIENT:[WARN] UDP connection timeout (11 so far), reconnection attempt 11
[12:51:27] NETCLIENT:[INFO] Connecting to UDP server…
[12:51:29] ANT : Rx Fail on channel 1
[12:51:33] FE-C 240 received
[12:51:35] ANT : Rx Fail on channel 1
[12:51:37] ANT : Rx Fail on channel 1
[12:51:38] ANT : Rx Fail on channel 2
[12:51:39] ANT : Rx Fail on channel 2
[12:51:40] ANT : Rx Fail on channel 2
[12:51:40] ANT : Rx Fail on channel 1
[12:51:41] ANT : Rx Fail on channel 1
[12:51:41] ANT : dID 1129213 MFG 89 Model 2900
[12:51:47] ANT : Rx Fail on channel 2
[12:51:49] FE-C 240 received
[12:51:50] FE-C 249 received
[12:51:50] ANT : Rx Fail on channel 1
[12:51:51] ANT : Rx Fail on channel 1
[12:51:51] ANT : Rx Fail on channel 2
[12:51:52] ANT : Rx Fail on channel 2
[12:51:57] NETCLIENT:[WARN] UDP connection timeout (12 so far), reconnection attempt 12
[12:51:57] NETCLIENT:[INFO] Connecting to UDP server…
[12:51:57] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:51:58] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:51:59] ANT : Rx Fail on channel 1
[12:51:59] ANT : Rx Fail on channel 2
[12:52:00] ANT : Rx Fail on channel 1
[12:52:02] ANT : Rx Fail on channel 1
[12:52:05] ANT : Rx Fail on channel 2
[12:52:06] FE-C 240 received
[12:52:11] ANT : Rx Fail on channel 1
[12:52:13] ANT : Rx Fail on channel 1
[12:52:14] ANT : dID 1129213 MFG 89 Model 2900
[12:52:14] NETCLIENT:[INFO] Sending telemetry…
[12:52:15] NETCLIENT:[INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
[12:52:15] NETCLIENT:[INFO] Telemetry successfully sent
[12:52:17] ANT : Rx Fail on channel 2
[12:52:21] ANT : Rx Fail on channel 1
[12:52:22] FE-C 240 received
[12:52:23] FE-C 249 received
[12:52:23] ANT : Rx Fail on channel 1
[12:52:23] ANT : Rx Fail on channel 2
[12:52:27] NETCLIENT:[WARN] UDP connection timeout (13 so far), reconnection attempt 13
[12:52:27] NETCLIENT:[INFO] Connecting to UDP server…
[12:52:29] ANT : Rx Fail on channel 2
[12:52:30] ANT : Rx Fail on channel 2
[12:52:30] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:52:31] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:52:31] ANT : Rx Fail on channel 1
[12:52:33] ANT : Rx Fail on channel 2
[12:52:33] ANT : Rx Fail on channel 1
[12:52:39] FE-C 240 received
[12:52:42] ANT : Rx Fail on channel 2
[12:52:43] ANT : Rx Fail on channel 1
[12:52:44] ANT : Rx Fail on channel 1
[12:52:47] ANT : dID 1129213 MFG 89 Model 2900
[12:52:47] ANT : Rx Fail on channel 1
[12:52:48] ANT : Rx Fail on channel 1
[12:52:50] ANT : Rx Fail on channel 1
[12:52:54] ANT : Rx Fail on channel 1
[12:52:55] ANT : Rx Fail on channel 1
[12:52:55] FE-C 240 received
[12:52:56] FE-C 249 received
[12:52:56] ANT : Rx Fail on channel 2
[12:52:57] ANT : Rx Fail on channel 2
[12:52:57] NETCLIENT:[WARN] UDP connection timeout (14 so far), reconnection attempt 14
[12:52:57] NETCLIENT:[INFO] Connecting to UDP server…
[12:52:57] ANT : Rx Fail on channel 1
[12:53:00] ANT : Rx Fail on channel 2
[12:53:03] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:53:04] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:53:05] ANT : Rx Fail on channel 1
[12:53:09] ANT : Rx Fail on channel 1
[12:53:09] ANT : Rx Fail on channel 2
[12:53:12] FE-C 240 received
[12:53:13] ANT : Rx Fail on channel 1
[12:53:14] NETCLIENT:[INFO] Sending telemetry…
[12:53:14] ANT : Rx Fail on channel 1
[12:53:15] NETCLIENT:[INFO] Telemetry successfully sent
[12:53:15] NETCLIENT:[INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
[12:53:16] ANT : Rx Fail on channel 1
[12:53:17] ANT : Rx Fail on channel 1
[12:53:18] ANT : Rx Fail on channel 1
[12:53:20] ANT : dID 1129213 MFG 89 Model 2900
[12:53:21] ANT : Rx Fail on channel 2
[12:53:22] ANT : Rx Fail on channel 2
[12:53:23] ANT : Rx Fail on channel 1
[12:53:25] ANT : Rx Fail on channel 1
[12:53:27] NETCLIENT:[WARN] UDP connection timeout (15 so far), reconnection attempt 15
[12:53:27] NETCLIENT:[INFO] Connecting to UDP server…
[12:53:28] FE-C 240 received
[12:53:29] FE-C 249 received
[12:53:30] ANT : Rx Fail on channel 1
[12:53:32] ANT : Rx Fail on channel 1
[12:53:33] ANT : Rx Fail on channel 2
[12:53:34] ANT : Rx Fail on channel 2
[12:53:36] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:53:37] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:53:37] ANT : Rx Fail on channel 1
[12:53:40] ANT : Rx Fail on channel 1
[12:53:42] ANT : Rx Fail on channel 1
[12:53:44] ANT : Rx Fail on channel 1
[12:53:45] FE-C 240 received
[12:53:46] ANT : Rx Fail on channel 1
[12:53:47] ANT : Rx Fail on channel 1
[12:53:48] ANT : Rx Fail on channel 2
[12:53:49] ANT : Rx Fail on channel 2
[12:53:53] ANT : dID 1129213 MFG 89 Model 2900
[12:53:55] ANT : Rx Fail on channel 1
[12:53:57] ANT : Rx Fail on channel 1
[12:53:57] NETCLIENT:[WARN] UDP connection timeout (16 so far), reconnection attempt 16
[12:53:57] NETCLIENT:[INFO] Connecting to UDP server…
[12:53:59] ANT : Rx Fail on channel 1
[12:54:01] ANT : Rx Fail on channel 2
[12:54:02] ANT : Rx Fail on channel 2
[12:54:08] ANT : Rx Fail on channel 1
[12:54:09] ANT : Rx Fail on channel 1
[12:54:09] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:54:10] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:54:12] ANT : Rx Fail on channel 1
[12:54:13] ANT : Rx Fail on channel 1
[12:54:14] NETCLIENT:[INFO] Sending telemetry…
[12:54:15] NETCLIENT:[INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
[12:54:15] ANT : Rx Fail on channel 1
[12:54:15] NETCLIENT:[INFO] Telemetry successfully sent
[12:54:16] ANT : Rx Fail on channel 2
[12:54:17] ANT : Rx Fail on channel 1
[12:54:18] FE-C 240 received
[12:54:19] ANT : Rx Fail on channel 1
[12:54:20] ANT : Rx Fail on channel 1
[12:54:23] ANT : Rx Fail on channel 1
[12:54:26] ANT : dID 1129213 MFG 89 Model 2900
[12:54:27] ANT : Rx Fail on channel 1
[12:54:27] NETCLIENT:[WARN] UDP connection timeout (17 so far), reconnection attempt 17
[12:54:27] NETCLIENT:[INFO] Connecting to UDP server…
[12:54:27] ANT : Rx Fail on channel 2
[12:54:28] ANT : Rx Fail on channel 1
[12:54:28] ANT : Rx Fail on channel 2
[12:54:29] ANT : Rx Fail on channel 1
[12:54:30] ANT : Rx Fail on channel 1
[12:54:31] ANT : Rx Fail on channel 1
[12:54:34] FE-C 240 received
[12:54:35] FE-C 249 received
[12:54:37] ANT : Rx Fail on channel 1
[12:54:40] ANT : Rx Fail on channel 1
[12:54:41] ANT : Rx Fail on channel 2
[12:54:41] ANT : Rx Fail on channel 1
[12:54:42] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:54:43] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:54:44] ANT : Rx Fail on channel 1
[12:54:45] ANT : Rx Fail on channel 1
[12:54:46] ANT : Rx Fail on channel 1
[12:54:47] ANT : Rx Fail on channel 1
[12:54:47] ANT : Rx Fail on channel 2
[12:54:51] FE-C 240 received
[12:54:51] ANT : Rx Fail on channel 1
[12:54:52] ANT : Rx Fail on channel 2
[12:54:54] ANT : Rx Fail on channel 2
[12:54:56] ANT : Rx Fail on channel 2
[12:54:57] NETCLIENT:[WARN] UDP connection timeout (18 so far), reconnection attempt 18
[12:54:57] NETCLIENT:[INFO] Connecting to UDP server…
[12:54:57] ANT : Rx Fail on channel 1
[12:54:59] ANT : Rx Fail on channel 1
[12:54:59] ANT : dID 1129213 MFG 89 Model 2900
[12:55:00] ANT : Rx Fail on channel 1
[12:55:03] ANT : Rx Fail on channel 1
[12:55:05] ANT : Rx Fail on channel 1
[12:55:05] ANT : Rx Fail on channel 2
[12:55:07] FE-C 240 received
[12:55:08] FE-C 249 received
[12:55:09] ANT : Rx Fail on channel 1
[12:55:10] ANT : Rx Fail on channel 1
[12:55:13] ANT : Rx Fail on channel 1
[12:55:14] NETCLIENT:[INFO] Sending telemetry…
[12:55:15] NETCLIENT:[INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
[12:55:15] NETCLIENT:[INFO] Telemetry successfully sent
[12:55:15] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:55:16] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:55:16] ANT : Rx Fail on channel 1
[12:55:18] ANT : Rx Fail on channel 2
[12:55:23] ANT : Rx Fail on channel 1
[12:55:24] FE-C 240 received
[12:55:26] ANT : Rx Fail on channel 1
[12:55:26] NETCLIENT:[ERROR] Error receiving TCP header [2] End of file
[12:55:27] NETCLIENT:[WARN] UDP connection timeout (19 so far), reconnection attempt 19
[12:55:27] NETCLIENT:[INFO] Connecting to UDP server…
[12:55:28] ANT : Rx Fail on channel 2
[12:55:29] ANT : Rx Fail on channel 2
[12:55:30] ANT : Rx Fail on channel 1
[12:55:31] ANT : Rx Fail on channel 2
[12:55:31] NETCLIENT:[INFO] TCP host 54.244.130.233:3023
[12:55:31] NETCLIENT:[INFO] Connecting to TCP server…
[12:55:32] NETCLIENT:[INFO] Saying hello to TCP server (largest wa is 1618138524971003)
[12:55:32] ANT : dID 1129213 MFG 89 Model 2900
[12:55:34] ANT : Rx Fail on channel 1
[12:55:40] ANT : Rx Fail on channel 1
[12:55:40] FE-C 240 received
[12:55:41] ANT : Rx Fail on channel 2
[12:55:42] ANT : Rx Fail on channel 2
[12:55:43] ANT : Rx Fail on channel 2
[12:55:44] ANT : Rx Fail on channel 1
[12:55:45] ANT : Rx Fail on channel 1
[12:55:46] ANT : Rx Fail on channel 2
[12:55:48] ANT : Rx Fail on channel 2
[12:55:48] ANT : Rx Fail on channel 1
[12:55:48] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:55:49] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:55:50] ANT : Rx Fail on channel 1
[12:55:50] ANT : Rx Fail on channel 2
[12:55:53] ANT : Rx Fail on channel 2
[12:55:53] ANT : Rx Fail on channel 1
[12:55:54] ANT : Rx Fail on channel 1
[12:55:55] ANT : Rx Fail on channel 2
[12:55:57] NETCLIENT:[WARN] UDP connection timeout (20 so far), reconnection attempt 20
[12:55:57] NETCLIENT:[INFO] Connecting to UDP server…
[12:55:57] FE-C 240 received
[12:55:57] ANT : Rx Fail on channel 1
[12:55:57] ANT : Rx Fail on channel 2
[12:55:58] ANT : Rx Fail on channel 1
[12:56:00] ANT : Rx Fail on channel 1
[12:56:05] ANT : dID 1129213 MFG 89 Model 2900
[12:56:06] ANT : Rx Fail on channel 1
[12:56:07] ANT : Rx Fail on channel 1
[12:56:08] ANT : Rx Fail on channel 2
[12:56:09] ANT : Rx Fail on channel 2
[12:56:13] FE-C 240 received
[12:56:14] FE-C 249 received
[12:56:14] NETCLIENT:[INFO] Sending telemetry…
[12:56:15] NETCLIENT:[INFO] UDP metrics {StC Rx: 0, Rx error: 0, CtS Tx: 0, Tx error: 0}
[12:56:15] NETCLIENT:[INFO] Telemetry successfully sent
[12:56:16] ANT : Rx Fail on channel 1
[12:56:21] ANT : Rx Fail on channel 2
[12:56:22] ANT : Rx Fail on channel 1
[12:56:22] ANT : dID 1129213 SW Revision 11523 SerialNum 15101
[12:56:23] ANT : Rx Fail on channel 1
[12:56:27] NETCLIENT:[WARN] UDP connection timeout (21 so far), reconnection attempt 21
[12:56:27] NETCLIENT:[INFO] Connecting to UDP server…
[12:56:27] ANT : Rx Fail on channel 1
[12:56:30] FE-C 240 received
[12:56:34] ANT : Rx Fail on channel 2
[12:56:35] ANT : Rx Fail on channel 1
[12:56:36] ANT : Rx Fail on channel 1
[12:56:37] ANT : Rx Fail on channel 1
[12:56:38] ANT : dID 1129213 MFG 89 Model 2900
[12:56:40] ANT : Rx Fail on channel 1
[12:56:42] ANT : Rx Fail on channel 1
[12:56:44] ANT : Rx Fail on channel 1
[12:56:45] ANT : Rx Fail on channel 2
[12:56:45] ANT : Rx Fail on channel 1
Which exact CPU? It’s probably this:
Processor Intel(R) Core™ i7-1065G7 CPU @ 1.30GHz, 1498 Mhz, 4 Core(s), 8 Logical Processor(s)
according to the system it is the above, selling company says the code name is
“Ice Lake”, which would make it 10th gen…
Is there any official Zwift page to follow any developments on this issue? @Dave_ZPCMR
Thought so. :confused: Nope, it’s been going on for months. That is the first semi-official response anyone’s really had from Zwift, hence why it warrants its own thread. Basically you should use another device to run Zwift if you want to ensure you avoid stability issues when using the integrated graphics on those CPUs.
Thanks for the clarity Dave, much appreciated :).
I guess that’s my afternoon booked, trying to find an old laptop which actually still works.
