My new Zwift Hub works great, with the exception of cadence. It’s sending a signal to my PC, but the reported cadence is way too low - usually 20-65 rpm. Is there some way to calibrate the way cadence is measured?
I’ve seen other people post similar, I think if you can pick up a cheap cadence sensor that might be your best bet
That crossed my mind, but I’d really prefer that the trainer sent the data it’s supposed to send. Surely, there is either a remedy or the trainer is faulty.
Trainer cadence readings are always a bit iffy, they have to kind of guess your cadence based on spikes in the power you put in. it might be able to get more accurate with a firmware update but who knows.
Raise a ticket with zwift and see what they say but they might replace it just for the same thing to happen. a cadence sensor can be picked up pretty cheap and will fix the problem.
