Zwiift put me on a wild goose chase to resolve the issue. Meanwhile, it’s been very erratic behaviour you put in more effort the wattage goes low. The resistance behaviour was also not relational to the gradient but the opposite. What I realized is that Zwift Hub is not a hardware solution but a simulation. What good is it if I have to use a sophisticated simulator with a 300% variance in accuracy? Hence decided to return to the Zwift hub. Once I get the refund. I will head for Neo 2T.
Latest update this morning and a reboot of everything cleared up the issues. Thanks
Hi @Nico_Cheetham
Are you still experiencing having to change Virtual Shifting to “Off” every time you load Zwift after updating to 1.50.2?
On free rides & races I am getting too little resistance from the Hub. Like I am in my highest 1-2 gears at 70% of my FTP.
Not sure if a new calibration would fix this, but the calibration option is currently not working… (known bug since last update).
With ERG on during workouts its fine. There should be an option to achieve something similar during free rides / races, or am I missing smth?
Turn off Virtual Shifting in Settings.
@Laurents_Mohr Calibration is now automatic if you’re running Zwift Hub firmware version > 4.0 (current as of this writing is 5.2.2); you can read more about auto calibration here: Zwift Hub Auto Calibration
@evan-zwift I am now getting absolutely no watts at all from my Zwift hub, despite the patch being released and installed.
I’ve sent multiple emails to support without response, My Hub is completely non-functional!
I really urgently need a solution to this. Can someone please contact me??
@Phil_Williams1 Sorry to hear about this issue - will get you connected to our support team immediately.
Update: Support has reached out directly.
Zwift nerfed by HUB again this week. That’s two weeks in a row! Come on guys, don’t make me regret buying a trainer that has had no physical issues. Quit the software goofs.
I’ve been trying to get support by mail for my problem for a few days, then every few days someone gets in touch with advice and then when I answer there is no answer.
Same issue has been going on since the update. Apple TV, Kickr V5 and zwift all running on current updates and no tension at all, low wattage. Figure refunds are due since everything was running fine until the updates were pushed. Extremely unhappy.
I have just installed my new Zwift Hub and updated the firmware for the hub and click devices. I am running the game on a Windows 11 pro device and Bluetooth connection is good for everything. The problem is that when I ride and change ‘gear’ the numbers change in the display but the actual resistance doe not change.
Hello @Brian_Gow welcome to Zwift forums and Zwift more broadly!
Shuji at Zwift HQ here. I’m looking through your server logs and see that you are brand new to Zwift.
A couple things I also see that might be tripping you up: During your troubleshooting you were logged in to the game simultaneously from a Windows , an iPhone 13 and iPad 13. Don’t do that. You always want to end each Zwift session before you start another. On mobile devices, backgrounding the app isn’t the same as force-closing it. Always force-close on your iPad or iPhone.
What might be happening in your case is that your trainer is already paired to the iPad when you’re pedaling on the Windows device.
I’d recommend uninstalling the main Zwift app from your mobile devices if you intent to run the game on the Windows laptop. You’ll want to run the Zwift Companion app on your smartphone so that you can use all of its collateral functionality.
All good now. Virtual shifting no longer an option in my settings.
Had a similar issue with my volt, acted like controllable resistance wasn’t connected at all. Try changing trainer difficulty in settings (you can go back to where it was, just mess around with it). For some reason that fixed the issue for me completely!
I’ve got the same, have to reconnect (plug out the kickr). Again new features, bugs added ![]()
Looks like another update was pushed today. Rebooted everything and….it worked! Now back to to work!
I did the update on Sunday, 10/29 and felt like I was going crazy with my effort and the watts being so low for the effort. Then, same thing today. In the resistance box, it says Wahoo and some number that is not mine. Do I reinstall? HELP!
Well I spoke too soon. It worked once…now same issues. Running Zwift version 1.51.0. Back to being very frustrated.
