Zwift hub one + Saris H3
Hi,I want to buy Zwift hub one, and rebuild my old Bianchi to fit with it. But does Zwift hub one works with a " Saris H3" trainer?
I’m using a apple laptop to run Zwift.
Best regards
Joakim
Short: No.
The Zwift Hub One is to be used with virtual shifting. Virtual shifting depends on support by the trainer - currently only the Zwift Hub, Wahoo Kickr Core, Kickr v6 and Kickr Move are compatible smart trainers.
Saris haven’t provided an update to support it, however you can use a 3rd party app (qzfitness.com) to pair the trainer and get virtual shifting. The latest version supports the Click and Play controllers for shifting, or you can shift on your phone. Talk to @Roberto_Viola if you want to know more about it. You could test it before you buy the Cog + Click package from Zwift.
Hi, QZ developer here. Let me know if you need help!
I thought so Magnus, thanks
Interesting Paul. I’ll talk to Saris for options and also look into the app you talked about.
I will, thanks
