Virtual shifting for wahoo kickr and other trainers!
I would really like to have virtual shifting for my Wahoo Kickr Core. It would be a huge upgrade for my setup and zwifting experience!
I have made the same request to wahoo (zwift says that they need to make firmware changes to make it possible) and I recommend all of you to contact the manufacturer of your trainer to.
So please, add virtual shifting for wahoo, Tacx and other trainers!
Zwift has stated they are 100% open to communication with other companies.
So you need to send this request directly to your trainers’ manufacturer.
(which you stated you did; just following this up for any passersby)
As long as its not locked only for Zwift use,… oh wait.
Q: Does Zwift Hub One only work with Zwift?
A: While we recommend using Zwift Hub One with Zwift for the most fun, immersive indoor cycling experience, Zwift Hub One can be connected to other platforms. Keep in mind that virtual shifting will only work with Zwift. If you want to use Zwift Hub One with another platform, you’ll need to remove the Zwift Cog and install a cassette.
Done! Send a request to wahoo
