Hi!
For me zwift crash everytime after I try to start the program.
Just updated to newest version never had any problems before.
Log file:
[18:19:35] Log Time: 18:19:35 2019-10-30
[18:19:35] Game Version: 1.0.41943
[18:19:35] Config: Shipping
[18:19:35] Launcher Version : 1.0.39
[18:19:35] Loading WAD file ‘assets/global.wad’ with file.
[18:19:35] Loading WAD file ‘assets/environment/ground/textures.wad’ with file.
[18:19:35] Loading WAD file ‘assets/UI/WhiteOrangeTheme/WhiteOrangeTheme.wad’ with file.
[18:19:35] Loading WAD file ‘assets/UI/minimap/minimap.wad’ with file.
[18:19:35] Loading WAD file ‘assets/UI/WhiteOrangeTheme/Scotty/Scotty.wad’ with file.
[18:19:35] Successful audio init!
[18:19:35] Loaded audio banks
[18:19:35] Initializing graphics window of size 0 x 0
[18:19:35] Attached Monitors:
[18:19:35] preferred monitor found at: 0,0
[18:19:35] monitor found at: -1920,16
[18:19:36] GFX_Initialize: GL_version = 3.1.0 NVIDIA 356.49
[18:19:36] GL_vendor = NVIDIA Corporation
[18:19:36] GL_render = Quadro M2000M/PCIe/SSE2
[18:19:36] Checking Extensions
[18:19:36] Shader Loaded successfully. data/shaders/Final/Blur.psh
[18:19:36] Calculating Graphics Score
[18:19:36] GFX: Found a vendor/model match for
[18:19:36] Initializing Render Targets
[18:19:36] Initializing Texture Systems
[18:19:36] Calling initialize_zwift_network()
[18:19:36] NETCLIENT:[INFO] CNL 2.3.0
[18:19:36] NETCLIENT:[INFO] Machine Id: 1-5d73d77a-c046-4928-834e-dec4e2c5ecf3
[18:19:36] Suceeded initializing graphics
[18:19:36] Shader Loaded successfully. data/shaders/Final/GFXDRAW_NoTexture.psh
[18:19:36] Shader Loaded successfully. data/shaders/Final/GFXDRAW_Textured.psh
[18:19:36] Shader Loaded successfully. data/shaders/Final/GFXDRAW_Textured_Simple.psh
[18:19:36] Shader Loaded successfully. data/shaders/Final/GFXDRAW_Textured_GammaCorrect.psh
[18:19:36] Loading WAD file ‘assets/fonts/font.wad’ with file.
[18:19:36] Shader Loaded successfully. data/shaders/Final/GFXDRAW_Font.psh
[18:19:36] Shader Loaded successfully. data/shaders/Final/GFXDRAW_FontW.psh
[18:19:36] Using medium graphics profile
[18:19:36] > res 1280x720(0x)
[18:19:36] Changed resolution to 1280 x 720 ( NO MSAA )
[18:19:36] > sres 1024x1024
[18:19:36] Changed shadow resolution to 1024 x 1024
[18:19:36] Syntax Error. USAGE: set VARNAME=VALUE
[18:19:36] Type ‘listvars’ for list of tweakable variables
[18:19:36] Unknown command “aniso 4”
[18:19:36] > set gSSAO=0
[18:19:36] > set gFXAA=1
[18:19:36] > set gSunRays=0
[18:19:36] > set gHeadlight=0
[18:19:36] > set gFoliagePercent=0.5
[18:19:36] > set gSimpleReflections=1
[18:19:36] > set gLODBias=1
[18:19:36] > res 1024x576
[18:19:36] Changed resolution to 1024 x 576
[18:19:36] OpenGL 3.1.0 NVIDIA 356.49 initialized
[18:19:36] Graphics Vendor: NVIDIA Corporation
[18:19:36] Graphics Renderer: Quadro M2000M/PCIe/SSE2
[18:19:36] RAM: 16GB
[18:19:36] CPU: Intel(R) Core™ i7-6700HQ CPU @ 2.60GHz
[18:19:36] ANT : Clearing network key on network 0.
[18:19:36] ANT : Clearing network key on network 1.
[18:19:36] ANT : Clearing network key on network 2.
[18:19:36] ANT : TX POWER ID
[18:19:36] ANT : RESET Complete, reason:
[18:19:36] ANT : RESET_CMD
[18:19:36] ANT : ANT USB receiver found
