Hello,
I am trying to use Zwift for the first time but it crashes at startup.
Here is the log where the last entry is “ANT DONGLE NOT CONNECTED”
Thanks!
[18:41:48] Log Time: 18:41:48 2021-07-26
[18:41:48] Game Version: 1.0.75178
[18:41:48] Config: Shipping
[18:41:48] Device: PC
[18:41:48] Launcher Version : 1.0.52
[18:41:48] Loading WAD file 'assets/global.wad' with file.
[18:41:49] Loading WAD file 'assets/environment/ground/textures.wad' with file.
[18:41:49] Loading WAD file 'assets/UI/WhiteOrangeTheme/WhiteOrangeTheme.wad' with file.
[18:41:49] Loading WAD file 'assets/UI/minimap/minimap.wad' with file.
[18:41:49] Loading WAD file 'assets/UI/WhiteOrangeTheme/Scotty/Scotty.wad' with file.
[18:41:49] Loading WAD file 'assets/UI/layouts/layouts.wad' with file.
[18:41:49] Loading WAD file 'assets/Environment/GrassTextures/GrassTextures.wad' with file.
[18:41:49] ERROR: Sky::Load(): Default not found
[18:41:49] ERROR: Sky::Load(): Japan not found
[18:41:49] ERROR: Sky::Load(): France not found
[18:41:49] Successful audio init!
[18:41:49] Loaded audio banks
[18:41:49] Initializing graphics window of size 0 x 0
[18:41:49] Attached Monitors:
[18:41:49] monitor found at: 0,0
[18:41:49] GLFW ERROR 65543: The requested client API version is unavailable
[18:41:49] GFX_Initialize: GL_version = 2.1.0 - Build 8.15.10.2900
[18:41:49] GL_vendor = Intel
[18:41:49] GL_render = Intel(R) HD Graphics
[18:41:49] Checking Extensions
[18:41:49] Calculating Graphics Score
[18:41:49] GFX: Found a vendor/model match for HD GRAPHICS
[18:41:49] Initializing Render Targets
[18:41:50] Initializing Texture Systems
[18:41:50] Shader Loaded successfully. data/shaders/Final/Blur.psh
[18:41:50] Calling initialize_zwift_network()
[18:41:50] NETCLIENT:[INFO] CNL 3.10.0
[18:41:50] NETCLIENT:[INFO] Machine Id: 1-23e5b853-e2f6-47cf-bf63-3c9f9dbbbb27
[18:41:50] Suceeded initializing graphics
[18:41:50] Shader Loaded successfully. data/shaders/Final/GFXDRAW_NoTexture.psh
[18:41:50] Shader Loaded successfully. data/shaders/Final/GFXDRAW_Textured.psh
[18:41:50] Shader Loaded successfully. data/shaders/Final/GFXDRAW_Textured_Simple.psh
[18:41:50] Shader Loaded successfully. data/shaders/Final/GFXDRAW_Textured_GammaCorrect.psh
[18:41:50] Loading WAD file 'assets/fonts/font.wad' with file.
[18:41:50] Shader Loaded successfully. data/shaders/Final/GFXDRAW_FontW.psh
[18:41:50] Using basic graphics profile
[18:41:50] > res 1024x576(0x)
[18:41:50] Changed resolution to 1024 x 576 ( NO MSAA )
[18:41:50] > sres 512x512
[18:41:50] Changed shadow resolution to 512 x 512
[18:41:50] Syntax Error. USAGE: set VARNAME=VALUE
[18:41:50] Type 'listvars' for list of tweakable variables
[18:41:50] Unknown command "aniso 4"
[18:41:50] > set gSSAO=0
[18:41:50] > set gFXAA=1
[18:41:50] > set gSunRays=0
[18:41:50] > set gHeadlight=0
[18:41:50] > set gFoliagePercent=0.5
[18:41:50] > set gSimpleReflections=1
[18:41:50] > set gLODBias=1
[18:41:50] OpenGL 2.1.0 - Build 8.15.10.2900 initialized
[18:41:50] Graphics Vendor: Intel
[18:41:50] Graphics Renderer: Intel(R) HD Graphics
[18:41:50] RAM: 8GB
[18:41:50] CPU: Intel(R) Pentium(R) CPU P6200 @ 2.13GHz
[18:41:50] ANT : ANT USB receiver NOT found
[18:41:50] Loading WAD file 'assets/UI/Achievements/goals.wad' with file.
[18:41:50] Loading WAD file 'assets/UI/Achievements/achievements.wad' with file.
[18:41:50] Downloader: "MapSchedule_v2.xml" downloaded successfully (manifest checksum not provided, i.e. -1).
[18:41:50] Registered segment 1 with hash id 888000
[18:41:50] Registered segment 2 with hash id 888001
[18:41:50] Registered segment 3 with hash id 888002
[18:41:50] Registered segment 4 with hash id 888003
[18:41:50] Registered segment 5 with hash id 888004
[18:41:50] Shader Loaded successfully. data/shaders/Final/GFXDRAW_Textured_ExtAlpha.psh
[18:41:50] Shader Loaded successfully. data/shaders/Final/Simpleshader.psh
[18:41:50] Shader Loaded successfully. data/shaders/Final/gde_nolighting.psh
[18:41:50] Shader Loaded successfully. data/shaders/Final/shadowmap.psh
[18:41:51] Shader Loaded successfully. data/shaders/Final/shadowmap_instanced.psh
[18:41:51] Shader Loaded successfully. data/shaders/Final/shadowmapHair.psh
[18:41:51] Shader Loaded successfully. data/shaders/Final/Glossy_shadowmapped.psh
[18:41:51] Shader Loaded successfully. data/shaders/Final/Road.psh
[18:41:51] Shader Loaded successfully. data/shaders/Final/RoadAccessory.psh
[18:41:51] Shader Loaded successfully. data/shaders/Final/RoadWet.psh
[18:41:51] Shader Loaded successfully. data/shaders/Final/HeatHaze.psh
[18:41:51] Shader Loaded successfully. data/shaders/Final/CausticPass.psh
[18:41:51] Shader Loaded successfully. data/shaders/Final/crepuscular.psh
[18:41:51] Loading Shader SSR
[18:41:51] ERROR: Missing Vertex Shader asset data/shaders/Final/SSR.vsh
[18:41:51] ERROR: GFX_CreateShaderFromFile(SSR): GFXAPI_CreateShaderFromFile failed!
[18:41:51] Shader Loaded successfully. data/shaders/Final/beam.psh
[18:41:51] Shader Loaded successfully. data/shaders/Final/beam_inside.psh
[18:41:51] Shader Loaded successfully. data/shaders/Final/defaultWorld.psh
[18:41:52] Shader Loaded successfully. data/shaders/Final/defaultWorldAO.psh
[18:41:52] Shader Loaded successfully. data/shaders/Final/defaultWorldBillboard.psh
[18:41:52] Shader Loaded successfully. data/shaders/Final/defaultworldphong.psh
[18:41:52] Shader Loaded successfully. data/shaders/Final/defaultWorldSimple.psh
[18:41:52] Shader Loaded successfully. data/shaders/Final/Hologram.psh
[18:41:52] Shader Loaded successfully. data/shaders/Final/RainbowHologram.psh
[18:41:52] Shader Loaded successfully. data/shaders/Final/Glossy_locked.psh
[18:41:52] Shader Loaded successfully. data/shaders/Final/londonTerrainShader.psh
[18:41:53] Shader Loaded successfully. data/shaders/Final/londonTerrainShader_HeightMap.psh
[18:41:53] Shader Loaded successfully. data/shaders/Final/franceTerrainShader.psh
[18:41:53] Shader Loaded successfully. data/shaders/Final/franceTerrainShader_HeightMap.psh
[18:41:53] Shader Loaded successfully. data/shaders/Final/japanTerrainShader.psh
[18:41:53] Shader Loaded successfully. data/shaders/Final/japanTerrainShader_HeightMap.psh
[18:41:53] Shader Loaded successfully. data/shaders/Final/innsbruckTerrainShader_HeightMap.psh
[18:41:53] Shader Loaded successfully. data/shaders/Final/innsbruckTerrainShader.psh
[18:41:54] Shader Loaded successfully. data/shaders/Final/bolognaTerrainShader_HeightMap.psh
[18:41:54] Shader Loaded successfully. data/shaders/Final/bolognaTerrainShader.psh
[18:41:54] Shader Loaded successfully. data/shaders/Final/yorkshireTerrainShader.psh
[18:41:54] Shader Loaded successfully. data/shaders/Final/yorkshireTerrainShader_HeightMap.psh
[18:41:54] Shader Loaded successfully. data/shaders/Final/richmondTerrainShader.psh
[18:41:54] Shader Loaded successfully. data/shaders/Final/richmondTerrainShader_HeightMap.psh
[18:41:54] Shader Loaded successfully. data/shaders/Final/WorkoutHologramPortal.psh
[18:41:55] Shader Loaded successfully. data/shaders/Final/WorkoutHologramPortalRing.psh
[18:41:55] Shader Loaded successfully. data/shaders/Final/FinalCopy.psh
[18:41:55] Shader Loaded successfully. data/shaders/Final/defaultWorld_Terrain.psh
[18:41:55] Shader Loaded successfully. data/shaders/Final/defaultWorld_TerrainHeightMap.psh
[18:41:55] Shader Loaded successfully. data/shaders/Final/shadowmap_TerrainHeightMap.psh
[18:41:55] Shader Loaded successfully. data/shaders/Final/defaultWorld_instanced.psh
[18:41:56] Shader Loaded successfully. data/shaders/Final/defaultWorld_notShadowed_instanced.psh
[18:41:56] Shader Loaded successfully. data/shaders/Final/defaultWorld_instanced_TerrainHeightMap.psh
[18:41:56] Shader Loaded successfully. data/shaders/Final/defaultWorld2Layer.psh
[18:41:57] Shader Loaded successfully. data/shaders/Final/defaultWorld2Layer_instanced.psh
[18:41:57] Shader Loaded successfully. data/shaders/Final/vegetation.psh
[18:41:57] Shader Loaded successfully. data/shaders/Final/vegetationTerrainHeightmapInstance.psh
[18:41:57] Shader Loaded successfully. data/shaders/Final/vegetationInstance.psh
[18:41:57] Shader Loaded successfully. data/shaders/Final/vegetationShadowmap.psh
[18:41:57] Shader Loaded successfully. data/shaders/Final/vegetationShadowMapInstance.psh
[18:41:58] Shader Loaded successfully. data/shaders/Final/accessory_instanced.psh
[18:41:58] Shader Loaded successfully. data/shaders/Final/defaultWorld_notShadowed.psh
[18:41:58] Shader Loaded successfully. data/shaders/Final/fxaa.psh
[18:41:58] Shader Loaded successfully. data/shaders/Final/UberPostprocess.psh
[18:41:58] Loading Shader RadialBlur
[18:41:58] ERROR: Missing Vertex Shader asset data/shaders/Final/RadialBlur.vsh
[18:41:58] ERROR: GFX_CreateShaderFromFile(RadialBlur): GFXAPI_CreateShaderFromFile failed!
[18:42:01] Shader Loaded successfully. data/shaders/Final/Invisibility.psh
[18:42:01] Shader Loaded successfully. data/shaders/Final/Invisibility_locked.psh
[18:42:01] Loading WAD file 'assets/Environment/SkyDome/sky.wad' with file.
[18:42:02] Shader Loaded successfully. data/shaders/Final/skinShader.psh
[18:42:02] Shader Loaded successfully. data/shaders/Final/shadowmapSkin.psh
[18:42:08] Shader Loaded successfully. data/shaders/Final/skinShaderHologram.psh
[18:42:08] Shader Loaded successfully. data/shaders/Final/sky.psh
[18:42:08] Shader Loaded successfully. data/shaders/Final/stars.psh
[18:42:08] Shader Loaded successfully. data/shaders/Final/moon.psh
[18:42:08] Shader Loaded successfully. data/shaders/Final/defaultParticles.psh
[18:42:08] Loading WAD file 'assets/Humans/Accessories/Accessories.wad' with file.
[18:42:08] Loading WAD file 'assets/Bikes/bikes_config.wad' with file.
[18:42:08] Loading WAD file 'assets/UI/WhiteOrangeTheme/Customization/Customization.wad' with file.
[18:42:08] Loading WAD file 'assets/UI/WhiteOrangeTheme/JerseyIcons/JerseyIcons.wad' with file.
[18:42:08] Wad assets/Humans/Accessories/Accessories.wad at 0x9792734d already loaded
[18:42:08] Loading WAD file 'assets/Humans/Accessories/Glasses/ZwiftGlasses.wad' with file.
[18:42:08] Loading WAD file 'assets/Humans/Accessories/Hair/Hair.wad' with file.
[18:42:09] Loading WAD file 'assets/Humans/Accessories/Hats/Hats.wad' with file.
[18:42:09] Loading WAD file 'assets/Humans/Accessories/Headband/Headband.wad' with file.
[18:42:09] Loading WAD file 'assets/Humans/Accessories/Helmets/ZwiftHelmet.wad' with file.
[18:42:09] Loading WAD file 'assets/Humans/Accessories/Shoes/Shoes.wad' with file.
[18:42:09] Loading WAD file 'assets/Humans/Accessories/Socks/Socks.wad' with file.
[18:42:09] Loading WAD file 'assets/Humans/Jerseys/Originals/originals_01.wad' with file.
[18:42:09] Loading WAD file 'assets/Humans/Jerseys/Originals/originals_02.wad' with file.
[18:42:09] Loading WAD file 'assets/Humans/Jerseys/Pro_Teams/pro_teams_01.wad' with file.
[18:42:10] Loading WAD file 'assets/Humans/Jerseys/Pro_Teams/pro_teams_02.wad' with file.
[18:42:10] Loading WAD file 'assets/Humans/Jerseys/Companies/Companies.wad' with file.
[18:42:10] Loading WAD file 'assets/Humans/Jerseys/Companies/Companies2.wad' with file.
[18:42:10] Loading WAD file 'assets/Humans/Jerseys/Companies/Companies3.wad' with file.
[18:42:10] Loading WAD file 'assets/Humans/Jerseys/Companies/Companies4.wad' with file.
[18:42:10] Loading WAD file 'assets/Humans/Jerseys/Companies/Companies5.wad' with file.
[18:42:11] Loading WAD file 'assets/Humans/Jerseys/Originals/camo_01.wad' with file.
[18:42:11] Loading WAD file 'assets/Humans/Jerseys/Specials/specials_01.wad' with file.
[18:42:11] Loading WAD file 'assets/Humans/Jerseys/Events/Events.wad' with file.
[18:42:11] Loading WAD file 'assets/Humans/Jerseys/Events/Events2.wad' with file.
[18:42:11] Loading WAD file 'assets/Humans/Jerseys/Clubs/Clubs.wad' with file.
[18:42:11] Loading WAD file 'assets/Humans/Jerseys/Clubs/Clubs2.wad' with file.
[18:42:11] Loading WAD file 'assets/Humans/Jerseys/Clubs/Clubs3.wad' with file.
[18:42:11] Loading WAD file 'assets/Humans/Jerseys/Pack01/Pack01.wad' with file.
[18:42:11] Loading WAD file 'assets/Humans/Jerseys/Pack02/Pack02.wad' with file.
[18:42:11] Loading WAD file 'assets/Humans/Jerseys/Charities/Charities.wad' with file.
[18:42:11] Loading WAD file 'assets/Humans/Clothes/Clothes.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Components/Zwift/Steel/ZwiftSteel.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Components/Campagnolo/SuperRecord/SuperRecord.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Components/Cassette/Cassette.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Components/Shimano/DuraAce/DuraAce.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Components/Specialized/Sworks/Sworks.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Components/Sram/SramRed/SramRed.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Components/Sram/SramXX1/SramXX1.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Components/CeramicSpeed/CeramicSpeed.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/data.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/BmcSLR01/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/BmcTimemachine01/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/Buffalo/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/BuffaloQhubeka/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/CannondaleCaad12/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/CannondaleEvo/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/CannondaleSynapseDisk2018/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/CannondaleSystemSix2019/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/Canyon_Aeroad/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/Canyon_Speedmax/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/Canyon_Ultimate/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/Cello/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/CerveloP5/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/CerveloP5x/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/CerveloR5/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/CerveloS3D/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/CerveloS5/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/DefaultOrange/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/DiamondBack_Andean/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/GiantDefyASL/frame.wad' with file.
[18:42:12] Loading WAD file 'assets/Bikes/Frames/GiantPropelAdvanced/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/LivLangma/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Parlee_ESX/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Pinarello_Dogma/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Pinarello_F8/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Pinarello_TT/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/PinarelloBolideTT2018/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/PinarelloDogmaF102019/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/RidleyHelium/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Scott_Foil/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Specialized_Allez/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Specialized_Amira/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Specialized_Roubaix/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Specialized_Tarmac/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Specialized_Venge/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/SpecializedAllezSprint2019/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/SpecializedShiv/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/SpecializedShiv2019/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Trek/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/TrekEmonda/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/TrekMadone/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/VentumOne/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Zwift_Aero/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Zwift_Bat/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Zwift_BW/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Zwift_BWConcept/frame.wad' with file.
[18:42:13] Loading WAD file 'assets/Bikes/Frames/Zwift_Carbon/frame.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Frames/Zwift_Concept/frame.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Frames/Zwift_Safety/frame.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Frames/Zwift_Steel/frame.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Frames/Zwift_TT/frame.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Frames/ZwiftSkeletal/frame.wad' with file.
[18:42:14] Unable to open WAD file "assets/Bikes/Frames/ScottSparkMountainBike2019/frame.wad".
[18:42:14] ERROR: Could not load wad file: assets/Bikes/Frames/ScottSparkMountainBike2019/frame.wad
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/data.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Zipp/Zipp_808_Firecrest/Firecrest808.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Zipp/Zipp_404_Firecrest/Firecrest404.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Zipp/Zipp_202_Firecrest/Firecrest202.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Lightweight/Meilenstein_Lightweight/Meilenstein_Lightweight.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Enve/EnveSES_2.2/Enve22.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Enve/EnveSES_3.5/EnveSES_3.5.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Enve/EnveSES_6.7/Enve67.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Enve/EnveSES7.8/EnveSES7.8.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Enve/EnveSES_8.9/Enve89.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Zipp/Zipp_Disc/Disc.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Mavic/CosmicCXR60c/CosmicCXR60c.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Zwift/Zwift_Concept/Concept.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Zwift/Zwift_Classic/Classic.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Zwift/Zwift_BW/BW.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Zwift/ZwiftSkeletal/wheels.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Zwift/Zwift_Bat/wheels.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Campagnolo/Campagnolo_Bora_Ultra/BoraUltra.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Bontrager/Aeolus5/Aeolus5.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Specialized/Roval/Roval.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Zwift/Zwift_Safety/Zwift_Safety.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/DefaultOrange/DefaultOrange.wad' with file.
[18:42:14] Loading WAD file 'assets/Bikes/Wheels/Giant/SLR/PropelAdvanced.wad' with file.
[18:42:23] FILE : Unable to load UI/WhiteOrangeTheme/JerseyIcons/Zwift_RaceLeader_thumb.tga
[18:42:23] FILE : Unable to load UI/WhiteOrangeTheme/JerseyIcons/TealPink2020_thumb.tga
[18:42:23] FILE : Unable to load UI/WhiteOrangeTheme/JerseyIcons/Twenty242021_thumb.tga
[18:42:23] FILE : Unable to load UI/WhiteOrangeTheme/Customization/RunningShirts/TealPink2020_thumb.tga
[18:42:23] Downloader: "Zwift_StreamingFiles_ver_cur.xml" downloaded successfully (manifest checksum not provided, i.e. -1).
[18:42:23] Streamer: StreamingFiles_ver_cur_Download_Callback - "Zwift_StreamingFiles_ver_cur.xml" download SUCCESS=0
[18:42:23] Shader Loaded successfully. data/shaders/Final/DropShadow.psh
[18:42:23] Loading WAD file 'assets/Humans/Male/male.wad' with file.
[18:42:24] Loading WAD file 'assets/Humans/Male/male_textures.wad' with file.
[18:42:24] Loading WAD file 'assets/Humans/Female/female.wad' with file.
[18:42:24] Loading WAD file 'assets/Humans/Female/female_textures.wad' with file.
[18:42:28] Shader Loaded successfully. data/shaders/Final/bib.psh
[18:42:28] Loading WAD file 'assets/UI/Challenges/challenges.wad' with file.
[18:42:28] Loading WAD file 'assets/UI/flags/flags.wad' with file.
[18:42:28] Loading WAD file 'assets/UI/Challenges/challenge_italy.wad' with file.
[18:42:28] Shader Loaded successfully. data/shaders/Final/defaultWorldBillboardGrass.psh
[18:42:29] SaveActivityService::GameLoadLevel -- Skipped Invalid World: 0
[18:42:29] GAME_LoadLevel() worldID = 0
[18:42:29] Loading WAD file 'assets/Worlds/world0/data.wad' with file.
[18:42:29] Loading WAD file 'assets/Worlds/world0/data_1.wad' with file.
[18:42:29] Loading WAD file 'assets/Environment/Road/FreshRoad/FreshRoad.wad' with file.
[18:42:29] Loading WAD file 'assets/Environment/Road/Cobblestone/Cobblestone.wad' with file.
[18:42:29] Loading WAD file 'assets/Environment/Road/DirtRoad/DirtRoad.wad' with file.
[18:42:29] Loading WAD file 'assets/Environment/Road/snowy/SnowRoad.wad' with file.
[18:42:30] Couldnt load road tex Environment\Road\FreshRoad\FreshRoadOneLine.tga
[18:42:30] Couldnt load road tex Environment\Road\FreshRoad\FreshRoadOneLineNml.tga
[18:42:30] Shader Loaded successfully. data/shaders/Final/colorRoadShader.psh
[18:42:30] AK::LoadBank(World0.bnk) failed: 2
[18:42:30] STEERING : Steering Mode Set to: None
[18:42:30] Save Profile Request: Repack Ridge Reset
[18:42:31] Shader Loaded successfully. data/shaders/Final/water.psh
[18:42:32] Shader Loaded successfully. data/shaders/Final/water_noholes.psh
[18:42:32] Loading WAD file 'assets/Humans/Jerseys/Originals/originals_01.wad' with file.
[18:42:32] Loading WAD file 'assets/Humans/Jerseys/Originals/originals_02.wad' with file.
[18:42:33] Got an access token
[18:42:33] Attempting Token Login...
[18:42:33] ANT : Setting network key on network 0...
[18:42:33] ANT : Setting network key on network 1...
[18:42:34] ANT : Setting network key on network 2...
[18:42:34] m_bDraftLockFixEnabled: ON (default, feature-flag setting unavailable)
[19:42:34] ANT DONGLE NOT CONNECTED
