Crash while loading makuri island - win 10
I have no idea what do do.
I was running Zwift till last spring using my windows 10, Intel i5 3470, 8gb RAM and my MSI NVDIA 750 ti with 2gb RAM,
I know it ist not the newest system but it worked fine for all other application I use.
When choosing makuri island zwift lauchens the blue zwift screen and then it crashed every time. The funny thing is, thant when launching watopia, erveything worked fine.
windows is up to date and also the graphic driver from nvidia was updated manually.
Here you can find the launcher log file:
[15:26:20 2021-12-02] Launcher: Checking for VerCur Override
[15:26:21 2021-12-02] Launcher: prefs.xml file found.
[15:26:21 2021-12-02] Launcher: This is an AutoStartup Launch.
[15:26:21 2021-12-02] Launcher: Auto Startup is Enabled.
[15:26:21 2021-12-02] Launcher: Launcher Version Number 1.0.52
[15:26:21 2021-12-02] Launcher: Checking for 64-bit OS
[15:26:21 2021-12-02] Launcher: Setting Sleep Callback
[15:26:21 2021-12-02] Launcher: Initializing UI Components
[15:26:21 2021-12-02] Launcher: Setting Browser Events
[15:26:21 2021-12-02] Launcher: Initializing Tray Components
[15:26:21 2021-12-02] Launcher: Initializing Patcher
[15:26:21 2021-12-02] Launcher: Setting Login URL
[15:26:22 2021-12-02] Launcher: prefs.xml file found.
[15:26:22 2021-12-02] Launcher: Found Launcher URL.
[15:26:22 2021-12-02] Launcher: Navigating to Login URL
[15:26:22 2021-12-02] Launcher: Launching silently.
[15:26:22 2021-12-02] Launcher: Starting silent update timer for 1 second.
[15:26:23 2021-12-02] Launcher: DoUpdateCheck() Called.
[15:26:23 2021-12-02] Launcher: ZwiftApp.exe is not running.
[15:26:23 2021-12-02] Launcher: Starting Update Check.
[15:26:23 2021-12-02] Launcher: prefs.xml file found.
[15:26:23 2021-12-02] Launcher: Checking for internet connection.
[15:26:23 2021-12-02] Patcher: Patcher Version Number: "1.3.0".
[15:26:23 2021-12-02] Patcher: Local download path set to "D:\Downloads\Zwift\".
[15:26:23 2021-12-02] Patcher: Server URL path set to "http://cdn.zwift.com/gameassets/Zwift_Updates_Root/".
[15:26:23 2021-12-02] Patcher: Local update path set to "".
[15:26:23 2021-12-02] Patcher: Kicking download of "Zwift_ver_cur.xml"...
[15:26:23 2021-12-02] Patcher: Kicking download of "Launcher_ver_cur.xml"...
[15:26:24 2021-12-02] Downloader: "Zwift_ver_cur.xml" downloaded successfully (manifest checksum not provided, i.e. -1).
[15:26:24 2021-12-02] Downloader: "Launcher_ver_cur.xml" downloaded successfully (manifest checksum not provided, i.e. -1).
[15:26:24 2021-12-02] Patcher: Completed downloading server XML version files (Game & Launcher).
[15:26:24 2021-12-02] Patcher: Fetching version attribute from file: "Zwift_ver_cur.xml"
[15:26:24 2021-12-02] Patcher: Local version is "1.0.100145".
[15:26:24 2021-12-02] Patcher: Server version is "1.0.100145".
[15:26:24 2021-12-02] Patcher: Local manifest is "Zwift_1.0.100145_b450422b_manifest.xml".
[15:26:24 2021-12-02] Patcher: Server manifest is "Zwift_1.0.100145_b450422b_manifest.xml".
[15:26:24 2021-12-02] Patcher: Server manifest file checksum is "-445295179".
[15:26:24 2021-12-02] Patcher: Server ver_cur checksum is "1677771087".
[15:26:24 2021-12-02] Patcher: Local Launcher version is "0.0.0".
[15:26:24 2021-12-02] Patcher: Server Launcher version is "0.0.0".
[15:26:24 2021-12-02] Patcher: Launcher URL for updating self is "www.zwift.com".
[15:26:24 2021-12-02] Patcher: No update available, deleting temp files...
[15:26:24 2021-12-02] Launcher: Checking Launcher Version.
[15:26:24 2021-12-02] Launcher: Checking for Game Update.
[15:26:24 2021-12-02] Launcher: No Update found.
[15:26:42 2021-12-02] Launcher: ZwiftApp.exe is not running.
[15:26:42 2021-12-02] Launcher: prefs.xml file found.
[15:26:42 2021-12-02] Launcher: Found Launcher URL.
[15:26:42 2021-12-02] Launcher: Zwift Window Opened. Checking for Game Update.
[15:26:43 2021-12-02] Launcher: DoUpdateCheck() Called.
[15:26:43 2021-12-02] Launcher: ZwiftApp.exe is not running.
[15:26:43 2021-12-02] Launcher: Starting Update Check.
[15:26:43 2021-12-02] Launcher: prefs.xml file found.
[15:26:43 2021-12-02] Launcher: Checking for internet connection.
[15:26:43 2021-12-02] Patcher: Patcher Version Number: "1.3.0".
[15:26:43 2021-12-02] Patcher: Local download path set to "D:\Downloads\Zwift\".
[15:26:43 2021-12-02] Patcher: Server URL path set to "http://cdn.zwift.com/gameassets/Zwift_Updates_Root/".
[15:26:43 2021-12-02] Patcher: Local update path set to "".
[15:26:43 2021-12-02] Patcher: Kicking download of "Zwift_ver_cur.xml"...
[15:26:43 2021-12-02] Patcher: Kicking download of "Launcher_ver_cur.xml"...
[15:26:43 2021-12-02] Downloader: "Zwift_ver_cur.xml" downloaded successfully (manifest checksum not provided, i.e. -1).
[15:26:43 2021-12-02] Downloader: "Launcher_ver_cur.xml" downloaded successfully (manifest checksum not provided, i.e. -1).
[15:26:43 2021-12-02] Patcher: Completed downloading server XML version files (Game & Launcher).
[15:26:43 2021-12-02] Patcher: Fetching version attribute from file: "Zwift_ver_cur.xml"
[15:26:43 2021-12-02] Patcher: Local version is "1.0.100145".
[15:26:43 2021-12-02] Patcher: Server version is "1.0.100145".
[15:26:43 2021-12-02] Patcher: Local manifest is "Zwift_1.0.100145_b450422b_manifest.xml".
[15:26:43 2021-12-02] Patcher: Server manifest is "Zwift_1.0.100145_b450422b_manifest.xml".
[15:26:43 2021-12-02] Patcher: Server manifest file checksum is "-445295179".
[15:26:43 2021-12-02] Patcher: Server ver_cur checksum is "1677771087".
[15:26:43 2021-12-02] Patcher: Local Launcher version is "0.0.0".
[15:26:43 2021-12-02] Patcher: Server Launcher version is "0.0.0".
[15:26:43 2021-12-02] Patcher: Launcher URL for updating self is "www.zwift.com".
[15:26:43 2021-12-02] Patcher: No update available, deleting temp files...
[15:26:43 2021-12-02] Launcher: Checking Launcher Version.
[15:26:43 2021-12-02] Launcher: Checking for Game Update.
[15:26:43 2021-12-02] Launcher: No Update found.
[15:26:45 2021-12-02] Launcher: ZwiftApp.exe is not running.
[15:26:45 2021-12-02] Launcher: Starting Zwift App.
[15:26:55 2021-12-02] Launcher: ZL has a valid process pointer and the flag HasExited is False.
[15:28:19 2021-12-02] Launcher: DoUpdateCheck() Called.
[15:28:19 2021-12-02] Launcher: ZL has a valid process pointer and the flag HasExited is True.
[15:28:19 2021-12-02] Launcher: Starting Update Check.
[15:28:19 2021-12-02] Launcher: prefs.xml file found.
[15:28:19 2021-12-02] Launcher: Checking for internet connection.
[15:28:19 2021-12-02] Patcher: Patcher Version Number: "1.3.0".
[15:28:19 2021-12-02] Patcher: Local download path set to "D:\Downloads\Zwift\".
[15:28:19 2021-12-02] Patcher: Server URL path set to "http://cdn.zwift.com/gameassets/Zwift_Updates_Root/".
[15:28:19 2021-12-02] Patcher: Local update path set to "".
[15:28:19 2021-12-02] Patcher: Kicking download of "Zwift_ver_cur.xml"...
[15:28:19 2021-12-02] Patcher: Kicking download of "Launcher_ver_cur.xml"...
[15:28:19 2021-12-02] Downloader: "Zwift_ver_cur.xml" downloaded successfully (manifest checksum not provided, i.e. -1).
[15:28:19 2021-12-02] Downloader: "Launcher_ver_cur.xml" downloaded successfully (manifest checksum not provided, i.e. -1).
[15:28:19 2021-12-02] Patcher: Completed downloading server XML version files (Game & Launcher).
[15:28:19 2021-12-02] Patcher: Fetching version attribute from file: "Zwift_ver_cur.xml"
[15:28:19 2021-12-02] Patcher: Local version is "1.0.100145".
[15:28:19 2021-12-02] Patcher: Server version is "1.0.100145".
[15:28:19 2021-12-02] Patcher: Local manifest is "Zwift_1.0.100145_b450422b_manifest.xml".
[15:28:19 2021-12-02] Patcher: Server manifest is "Zwift_1.0.100145_b450422b_manifest.xml".
[15:28:19 2021-12-02] Patcher: Server manifest file checksum is "-445295179".
[15:28:19 2021-12-02] Patcher: Server ver_cur checksum is "1677771087".
[15:28:19 2021-12-02] Patcher: Local Launcher version is "0.0.0".
[15:28:19 2021-12-02] Patcher: Server Launcher version is "0.0.0".
[15:28:19 2021-12-02] Patcher: Launcher URL for updating self is "www.zwift.com".
[15:28:19 2021-12-02] Patcher: No update available, deleting temp files...
[15:28:19 2021-12-02] Launcher: Checking Launcher Version.
[15:28:19 2021-12-02] Launcher: Checking for Game Update.
[15:28:19 2021-12-02] Launcher: No Update found.
and here is the end of the log file:
[15:28:09] FE-C 26 received
[15:28:10] FE-C 224 received
[15:28:10] FE-C 17 received
[15:28:11] FE-C 26 received
[15:28:11] FE-C 224 received
[15:28:12] FE-C 26 received
[15:28:12] FE-C 224 received
[15:28:12] FE-C 17 received
[15:28:13] FE-C 26 received
[15:28:13] FE-C 224 received
[15:28:14] FE-C 26 received
[15:28:14] FE-C 224 received
[15:28:15] FE-C 26 received
[15:28:15] FE-C 17 received
[15:28:15] FE-C 224 received
[15:28:16] FE-C 26 received
[15:28:16] FE-C 224 received
[15:28:17] FE-C 26 received
[15:28:17] Registered segment 15 with hash id 5351155048
[15:28:17] Registered segment 16 with hash id -9223372031503620760
[15:28:17] Registered segment 17 with hash id 13941612717
[15:28:17] Registered segment 18 with hash id -9223372022913163091
[15:28:17] Registered segment 19 with hash id 1063265653
[15:28:17] Registered segment 20 with hash id -9223372035791510155
[15:28:17] Registered segment 21 with hash id 9653119714
[15:28:17] Registered segment 22 with hash id -9223372027201656094
[15:28:17] Registered segment 23 with hash id 1017688671
[15:28:17] Registered segment 24 with hash id -9223372035837087137
[15:28:17] Registered segment 25 with hash id 31123894722
[15:28:17] Registered segment 26 with hash id -9223372005730881086
[15:28:17] Registered segment 27 with hash id 35423495305
[15:28:17] Registered segment 28 with hash id -9223372001431280503
[15:28:17] Registered segment 29 with hash id 39700801768
[15:28:17] Registered segment 30 with hash id -9223371997153974040
[15:28:17] Registered segment 31 with hash id 44010445334
[15:28:17] Registered segment 32 with hash id -9223371992844330474
[15:28:17] Registered segment 33 with hash id 48304718314
[15:28:17] Registered segment 34 with hash id -9223371988550057494
[15:28:17] FE-C 224 received
[15:28:17] FE-C 17 received
[15:28:18] ANT  : Rx Fail on channel 1
[15:28:18] ERROR: ZwiftApp Crashed
Anyone can help me? thank you in advance
I just saw that in the log file there is a ANT error. But I think this is not the reason because in Watopia ANT+ seems to be ok…
here is another logfile with more information.
18:24:39] Loading WAD file ‘assets/Bikes/Wheels/DefaultOrange/DefaultOrange.wad’ with file.
[18:24:39] Loading WAD file ‘assets/Bikes/Wheels/Giant/SLR/PropelAdvanced.wad’ with file.
[18:24:40] ERROR: Accessory::GetThumbnailTextureHandle Error - Asset Load Failure - Cannot find thumbnail texture - UI/WhiteOrangeTheme/JerseyIcons/Zwift_RaceLeader_thumb.tga
[18:24:40] ERROR: Accessory::GetThumbnailTextureHandle Error - Asset Load Failure - Cannot find thumbnail texture - UI/WhiteOrangeTheme/JerseyIcons/TealPink2020_thumb.tga
[18:24:41] ERROR: Accessory::GetThumbnailTextureHandle Error - Asset Load Failure - Cannot find thumbnail texture - UI/WhiteOrangeTheme/JerseyIcons/Twenty242021_thumb.tga
[18:24:42] ERROR: Accessory::GetThumbnailTextureHandle Error - Asset Load Failure - Cannot find thumbnail texture - UI/WhiteOrangeTheme/Customization/RunningShirts/TealPink2020_thumb.tga
[18:24:42] ERROR: Accessory::GetThumbnailTextureHandle Error - Asset Load Failure - Cannot find thumbnail texture - UI/WhiteOrangeTheme/Customization/RunningShorts/TealPink2020_thumb.tga
[18:24:42] ERROR: Accessory::GetThumbnailTextureHandle Error - Asset Load Failure - Cannot find thumbnail texture - UI/WhiteOrangeTheme/Customization/Glasses/Glasses_TealPink2020Glasses01_thumb.tga
[18:24:42] ERROR: Accessory::GetThumbnailTextureHandle Error - Asset Load Failure - Cannot find thumbnail texture - UI/WhiteOrangeTheme/Customization/Glasses/Glasses_TealPink2020Glasses02_thumb.tga
[18:24:45] FILE : Unable to load UI/WhiteOrangeTheme/JerseyIcons/Zwift_RaceLeader_thumb.tga
[18:24:45] FILE : Unable to load UI/WhiteOrangeTheme/JerseyIcons/TealPink2020_thumb.tga
[18:24:45] FILE : Unable to load UI/WhiteOrangeTheme/JerseyIcons/Twenty242021_thumb.tga
[18:24:45] FILE : Unable to load UI/WhiteOrangeTheme/Customization/RunningShirts/TealPink2020_thumb.tga
[18:24:45] Shader Loaded successfully. data/shaders/Final/DropShadow.psh
[18:24:45] Loading WAD file ‘assets/Humans/Male/male.wad’ with file.
[18:24:45] Loading WAD file ‘assets/Humans/Male/male_textures.wad’ with file.
[18:24:45] Loading WAD file ‘assets/Humans/Female/female.wad’ with file.
[18:24:45] Loading WAD file ‘assets/Humans/Female/female_textures.wad’ with file.
[18:24:46] Shader Loaded successfully. data/shaders/Final/bib.psh
[18:24:46] Loading WAD file ‘assets/UI/Challenges/challenges.wad’ with file.
[18:24:46] ERROR: CriticalPowerCurve::Save Query; pOutDataPoints is NULL
18:24:53] Tried to load a valid xml file, but it seems to not really be a ZWO file?
[18:24:53] LoadWorkout failed to load.
[18:24:53] Failed workout path: TrainingPlans/PRL100_2018.xml
[18:24:53] Tried to load a valid xml file, but it seems to not really be a ZWO file?
[18:24:53] Failed workout path: TrainingPlans/PRL46.xml
[18:24:53] Failed workout path: TrainingPlans/TT_Build.xml
[18:24:53] Failed workout path: TrainingPlans/running_101.xml
[18:24:53] Failed workout path: TrainingPlans/cycling_101.xml
[18:24:53] Failed workout path: TrainingPlans/bike_ftp_multi.xml
[18:24:53] Failed workout path: TrainingPlans/Coast_Ride.xml
[18:24:53] Failed workout path: TrainingPlans/mcmillan_adv_half.xml
[18:24:53] Failed workout path: TrainingPlans/marathon_phase2.xml
[18:24:53] Failed workout path: TrainingPlans/marathon_phase1.xml
[18:24:53] Failed workout path: TrainingPlans/running201_5k.xml
[18:24:53] Failed workout path: TrainingPlans/Pebble_Pounder.xml
[18:24:53] Failed workout path: TrainingPlans/Dirt_Destroyer.xml
[18:24:53] Failed workout path: TrainingPlans/Singletrack_Slayer.xml
[18:24:53] Failed workout path: TrainingPlans/zwift_racing.xml
[18:24:53] Failed workout path: TrainingPlans/BackToFitness.xml
[18:24:53] NETCLIENT:[INFO] TCP disconnected
[18:24:53] NETCLIENT:[INFO] TCP host 54.245.49.210:3023
[18:24:53] NETCLIENT:[INFO] Connecting to TCP server…
[18:24:53] NETCLIENT:[INFO] Saying hello to TCP server (largest wa is 0)
[18:24:53] Loading WAD file ‘assets/Workouts/workouts.wad’ with file.
[18:24:53] Loaded training plan ‘Back to Fitness’ : 1933759722
[18:24:53] Loaded training plan ‘PRL100 2019’ : -1879684214
[18:24:53] Loaded training plan ‘PRL46 2019’ : 1979360334
[18:24:53] Loaded training plan ‘FTP Builder’ : 1803127634
[18:24:53] Loaded training plan ‘Active Offseason’ : 2048408838
[18:25:00] ANT : Channel opened
[18:25:00] Device List:
[18:25:00] ==========================================================
[18:25:00] Cadence: ANT+ Trainer 50255 (0x11C44F) [ANT]
[18:25:00] Controllable Trainer: ANT+ Trainer 50255 (0x11C44F) [ANT]
[18:25:00] Power: ANT+ Trainer 50255 (0x11C44F) [ANT]
[18:25:00] “” adding component type: 6 (ANT)
[18:25:00] “Powermeter 50255” adding component type: 1 (ANT)
[18:25:00] Non-Selected: Powermeter 50255 (0xBC44F) [ANT]
[18:25:00] NETWORK:error (6) sending player state
[18:25:00] NETCLIENT:[WARN] Auxiliary Controller failed to shut down tcp socket: ‘Eine Anforderung zum Senden oder Empfangen von Daten wurde verhindert, da der Socket nicht verbunden ist und (beim Senden über einen Datagrammsocket mit einem sendto-Aufruf) keine Adresse angegeben wurde.’ (10057)
[18:25:00] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘Der E/A-Vorgang wurde wegen eines Threadendes oder einer Anwendungsanforderung abgebrochen.’ (995)
[18:25:00] FE-C 224 received
[18:25:01] FE-C 17 received
[18:25:01] “” adding component type: 6 (ANT)
[18:25:01] ANT : [PowerMeter] CrankPower: EC: 046 WT: 046 Period: 09624 AccumTorque: 49190
[18:25:01] ANT : [PowerMeter] Vang = 62.83 radians/sec Tavg: 32.71 nm Pavg: 2055.09 watts
[18:25:01] “Powermeter 48834” adding component type: 1 (ANT)
[18:25:01] Device List:
[18:25:01] ==========================================================
[18:25:01] Cadence: ANT+ Trainer 50255 (0x11C44F) [ANT]
[18:25:01] Controllable Trainer: ANT+ Trainer 50255 (0x11C44F) [ANT]
[18:25:01] Power: ANT+ Trainer 50255 (0x11C44F) [ANT]
[18:25:01] Non-Selected: Powermeter 50255 (0xBC44F) [ANT]
[18:25:01] Non-Selected: Powermeter 48834 (0xBBEC2) [ANT]
[18:25:01] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.0.111:21587
[18:25:01] NETWORK:error (6) sending player state
[18:25:01] FE-C 26 received
[18:25:02] ANT : Rx Fail on channel 1
[18:25:02] ANT : Stopping ANT search (mfg network 0)
[18:25:02] ANT : Closed channel 0
[18:25:02] ANT : Channel 0 Closed
[18:25:02] ANT : Unassign Channel
[18:25:02] ANT : Unassigned Channel
[18:25:02] ANT : Starting ANT search (mfg network 1)
[18:25:02] ANT : Channel Assigned
[18:25:02] ANT : Setting Channel ID for chan 0 (device 00)…
[18:25:02] ANT : Unknown response
[18:25:02] ANT : Channel ID Set
[18:25:02] ANT : Radio Frequency set
[18:25:02] ANT : Opening channel 0
[18:25:02] ANT : Channel opened
[18:25:02] Setting sport to CYCLING
[18:25:02] ANT : Stopping ANT search (mfg network 1)
[18:25:02] STEERING : Steering Mode Set to: None
[18:25:02] Loading WAD file ‘assets/Worlds/world9/data_1.wad’ with file.
[18:25:02] Loading routes…
[18:25:02] WARN : Load Route Warning - Cannot find leadincheckpoint in data/Worlds/world9/routes/routes0.xml
[18:25:02] WARN : Load Route Warning - Cannot find leadinhighrescheckpoint in data/Worlds/world9/routes/routes0.xml
[18:25:02] WARN : Load Route Warning - Cannot find leadincheckpoint in data/Worlds/world9/routes/routes2.xml
[18:25:02] WARN : Load Route Warning - Cannot find leadinhighrescheckpoint in data/Worlds/world9/routes/routes2.xml
[18:25:02] WARN : Load Route Warning - Cannot find leadincheckpoint in data/Worlds/world9/routes/routes7.xml
[18:25:02] WARN : Load Route Warning - Cannot find leadinhighrescheckpoint in data/Worlds/world9/routes/routes7.xml
[18:25:02] WARN : Load Route Warning - Cannot find leadincheckpoint in data/Worlds/world9/routes/routes19.xml
[18:25:02] WARN : Load Route Warning - Cannot find leadinhighrescheckpoint in data/Worlds/world9/routes/routes19.xml
[18:25:02] WARN : Load Route Warning - Cannot find leadincheckpoint in data/Worlds/world9/routes/routes20.xml
[18:25:02] WARN : Load Route Warning - Cannot find leadinhighrescheckpoint in data/Worlds/world9/routes/routes20.xml
[18:25:02] WARN : Load Route Warning - failed to open “data/Worlds/world9/routes/routes21.xml”
[18:25:02] Route manager info: 81 routes
[18:25:02] Select Route in DropIn Dialog Constructor
[18:25:02] Setting Route: Flatland Loop
[18:25:02] Calculating route stats for 120 CPs
[18:25:02] Printing Regular Route. Decisions Count 11. Infinite loop start at: 0 Finite loop start at: -1, end at: -1 for -1 loops
[18:25:02] Marker Id: 3, Turn: STRAIGHT, Direction: REVERSE
[18:25:02] Marker Id: 8, Turn: STRAIGHT, Direction: REVERSE
[18:25:02] Marker Id: 20, Turn: STRAIGHT, Direction: REVERSE
[18:25:02] Marker Id: 22, Turn: STRAIGHT, Direction: REVERSE
[18:25:02] Marker Id: 1, Turn: STRAIGHT, Direction: REVERSE
[18:25:02] Marker Id: 11, Turn: STRAIGHT, Direction: REVERSE
[18:25:02] Marker Id: 13, Turn: STRAIGHT, Direction: REVERSE
[18:25:02] Marker Id: 14, Turn: STRAIGHT, Direction: REVERSE
[18:25:02] Marker Id: 7, Turn: RIGHT, Direction: REVERSE
[18:25:02] Marker Id: 5, Turn: STRAIGHT, Direction: REVERSE
[18:25:02] Marker Id: 18, Turn: STRAIGHT, Direction: REVERSE
[18:25:02] Route stats: 1285540.000000cm long with 0.100000cm leadin, 9930.000000cm ascent
[18:25:02] FE-C 26 received
[18:25:02] R2H feature flag = enabled
[18:25:02] FE-C SIM GRADE 0.013
[18:25:02] NETWORK:error (6) sending player state
[18:25:02] Starting critical power curve search job (1614079) mTimeStamp = 10.02200 m_lastSearchTime = 10.02200 calculating=false
[18:25:02] ANT : Transfer Completed.
[18:25:02] ANT : FET grade set successfully
[18:25:03] FE-C 224 received
[18:25:03] FE-C 26 received
[18:25:03] NETWORK:error (6) sending player state
[18:25:03] FE-C SIM GRADE 0.013
[18:25:03] FE-C 17 received
[18:25:03] ANT : Transfer Completed.
[18:25:03] ANT : FET grade set successfully
[18:25:03] NETWORK:GroupEvents: Success: Queried active group events – Count=100.
[18:25:04] FE-C 224 received
[18:25:04] NETWORK:error (6) sending player state
[18:25:04] FE-C SIM GRADE 0.013
[18:25:04] FE-C 26 received
[18:25:04] ANT : Transfer Completed.
[18:25:04] ANT : FET grade set successfully
[18:25:04] NETWORK:GroupEvents: Success: Queried active group events – Count=100.
[18:25:05] FE-C 224 received
[18:25:05] NETWORK:error (6) sending player state
[18:25:05] FE-C SIM GRADE 0.013
[18:25:05] FE-C 26 received
[18:25:05] ANT : Transfer Completed.
[18:25:05] ANT : FET grade set successfully
[18:25:06] FE-C 224 received
[18:25:06] FE-C 17 received
[18:25:06] NETCLIENT:[WARN] Auxiliary Controller failed to shut down tcp socket: ‘Eine Anforderung zum Senden oder Empfangen von Daten wurde verhindert, da der Socket nicht verbunden ist und (beim Senden über einen Datagrammsocket mit einem sendto-Aufruf) keine Adresse angegeben wurde.’ (10057)
[18:25:06] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘Der E/A-Vorgang wurde wegen eines Threadendes oder einer Anwendungsanforderung abgebrochen.’ (995)
[18:25:06] NETWORK:error (6) sending player state
[18:25:06] FE-C SIM GRADE 0.013
[18:25:06] FPS 59.88, 3101, 14640, -2099
[18:25:06] ANT : Transfer Completed.
[18:25:06] ANT : FET grade set successfully
[18:25:07] FE-C 26 received
[18:25:07] FE-C 224 received
[18:25:07] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.0.111:21587
[18:25:07] NETWORK:error (6) sending player state
[18:25:07] FE-C SIM GRADE 0.013
[18:25:07] SaveActivityService::GameLoadLevel Creating New Activity {worldId: 9}
[18:25:07] SaveActivityService::InitializeNewActivity with {worldId: 9, sport: CYCLING}
[18:25:07] SaveActivityService FIT_CreateActivityFile
[18:25:07] ZNet::SaveActivity calling zwift_network::save_activity with {name: Zwift - Makuri Islands, bFinalSave: False, fitFileNameToUpload: D:\Dokumente/Zwift/Activities/inProgressActivity.fit, fitFileNameShort: 2021-12-02-18-25-07.fit}
[18:25:07] GAME_LoadLevel() worldID = 9
[18:25:07] ANT : Transfer Completed.
[18:25:07] ANT : FET grade set successfully
[18:25:07] Loading WAD file ‘assets/Worlds/world9/data.wad’ with file.
[18:25:07] Loading WAD file ‘assets/Worlds/world9/data_1.wad’ with file.
[18:25:08] NETCLIENT:[INFO] Activity Upload: load fit file from path D:\Dokumente/Zwift/Activities/inProgressActivity.fit
[18:25:08] NETCLIENT:[INFO] Activity Upload: fit file is length 584
[18:25:08] FE-C 26 received
[18:25:08] Unable to open WAD file “assets/Environment/Road/YellowLines/YellowLines.wad”.
[18:25:08] ERROR: Could not load wad file: assets/Environment/Road/YellowLines/YellowLines.wad
[18:25:08] Unable to open WAD file “assets/Environment/Road/2Lane/2Lane.wad”.
[18:25:08] ERROR: Could not load wad file: assets/Environment/Road/2Lane/2Lane.wad
[18:25:08] Unable to open WAD file “assets/Environment/Road/3Lane/3Lane.wad”.
[18:25:08] ERROR: Could not load wad file: assets/Environment/Road/3Lane/3Lane.wad
[18:25:08] Unable to open WAD file “assets/Environment/Road/BrickRoad/BrickRoad.wad”.
[18:25:08] ERROR: Could not load wad file: assets/Environment/Road/BrickRoad/BrickRoad.wad
[18:25:08] Loading WAD file ‘assets/Environment/Road/Cobblestone/Cobblestone.wad’ with file.
[18:25:08] Loading WAD file ‘assets/Environment/Road/RideLondonRoad/RideLondonRoad.wad’ with file.
[18:25:08] FE-C 224 received
[18:25:08] Loading WAD file ‘assets/Environment/Road/RideLondonRoad/RideLondonRoad2.wad’ with file.
[18:25:08] Loading WAD file ‘assets/Environment/Road/RideLondonRoad/RideLondonRoad3.wad’ with file.
[18:25:08] FE-C 17 received
[18:25:09] FE-C 26 received
[18:25:09] FE-C 224 received
[18:25:10] ANT : dID 1164367 SW Revision 18687 SerialNum 185000255
[18:25:10] FE-C 26 received
[18:25:11] FE-C 224 received
[18:25:11] FE-C 26 received
[18:25:12] FE-C 224 received
[18:25:12] FE-C 26 received
[18:25:12] NETCLIENT:[WARN] Auxiliary Controller failed to shut down tcp socket: ‘Eine Anforderung zum Senden oder Empfangen von Daten wurde verhindert, da der Socket nicht verbunden ist und (beim Senden über einen Datagrammsocket mit einem sendto-Aufruf) keine Adresse angegeben wurde.’ (10057)
[18:25:12] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘Der E/A-Vorgang wurde wegen eines Threadendes oder einer Anwendungsanforderung abgebrochen.’ (995)
[18:25:12] FE-C 17 received
[18:25:13] ANT : Rx Fail on channel 1
[18:25:13] FE-C 224 received
[18:25:13] FE-C 26 received
[18:25:14] FE-C 224 received
[18:25:14] FE-C 26 received
[18:25:15] FE-C 224 received
[18:25:15] FE-C 17 received
[18:25:16] FE-C 26 received
[18:25:16] FE-C 224 received
[18:25:17] FE-C 26 received
[18:25:17] FE-C 224 received
[18:25:17] Registered segment 15 with hash id 5351155048
[18:25:17] Registered segment 16 with hash id -9223372031503620760
[18:25:17] Registered segment 17 with hash id 13941612717
[18:25:17] Registered segment 18 with hash id -9223372022913163091
[18:25:17] Registered segment 19 with hash id 1063265653
[18:25:17] Registered segment 20 with hash id -9223372035791510155
[18:25:17] Registered segment 21 with hash id 9653119714
[18:25:17] Registered segment 22 with hash id -9223372027201656094
[18:25:17] Registered segment 23 with hash id 1017688671
[18:25:17] Registered segment 24 with hash id -9223372035837087137
[18:25:17] Registered segment 25 with hash id 31123894722
[18:25:17] Registered segment 26 with hash id -9223372005730881086
[18:25:17] Registered segment 27 with hash id 35423495305
[18:25:17] Registered segment 28 with hash id -9223372001431280503
[18:25:17] Registered segment 29 with hash id 39700801768
[18:25:17] Registered segment 30 with hash id -9223371997153974040
[18:25:17] Registered segment 31 with hash id 44010445334
[18:25:17] Registered segment 32 with hash id -9223371992844330474
[18:25:17] Registered segment 33 with hash id 48304718314
[18:25:17] Registered segment 34 with hash id -9223371988550057494
[18:25:17] FE-C 17 received
[18:25:18] FE-C 26 received
[18:25:18] ERROR: ZwiftApp Crashed
[18:25:18] ANT : Rx Fail on channel 1
Looks to be the same issue others have reported.
Zwift crashs while loading Makuri Island,
Win 10 on i5 3470 with msi geforce 750ti 2gB and 8GB RAM.
Other worlds run fine most of the time…
What could I do?
Here is the log
Does it always crash or just sometimes?
Always, during the “loading makuri island” screen zwift crashes or freezes.
I assume you tried to re install Zwift.
While loading how much CPU and GPU does the PC use.
Around 35 percent cpu and 70 percent RAM were used when crashing.
yes, zwift was installed multiple times before asking here in this forum…
That’s strange. I do wonder if this has to do with the Makuri Islands world being more resource intensive.
It could also be that too many processes are taking up RAM on your PC, and there aren’t enough resources left for Zwift to properly load the world.
Since this happens every time, though, maybe there are background processes that start up with your PC using up a portion of your RAM, or programs you frequently use/have open like a browser.
Were you able to load Makuri Islands before on this PC?
Looking on benchmarks my GTX 1650 (low level GPU for gaming) is about +150% above your GTX 750 ti - I believe that could be the reason.
Look at this
I have now reinstalled my pc with a fresh and clean win 10 installation.
Next time Makuri Island is up, i will try it again…
I have the same problem. New Zwift version and new GPU driver installed. It seems that my Geforce 840m has a running out of the 2GB when loading Makuri island.
VRAM capacity is not the problem. GPUs with 2GB of VRAM have no issue running Zwift, or loading Makuri Islands.
See Makuri Islands crashing after Neokyo update [Windows 8]
I have changed the size of swap file from previous 0 to ‘Size is managed by the system’ and now Makuri Island is loaded without crashing. Perhaps it is a coincidence?
I have an old computer with only 2 Gb memory, running Win 10.
Increased the page file settings to: minimum 5500 MB and max 8000 MB.
To my surprise it’s working now.
When you make the page file too small, it still crashes.
After reinstallation my win 10 pc, everything seems to work fine now.
thank you for the help!
I have yet to be able to open Makuri Islands. It opens up the blue screen then freezes. Also after sometime in other worlds my rides freeze in repetition? any help? It is getting very frustrating and upsetting.
System Information
  Time of this report: 2/19/2022, 07:29:09
         Machine name: LAPTOP-49RME54D
           Machine Id: {7138C6D3-0D1D-4C77-BECE-47599F8A58EC}
     Operating System: Windows 11 Home 64-bit (10.0, Build 22000) (22000.co_release.210604-1628)
             Language: English (Regional Setting: English)
  System Manufacturer: HP
         System Model: HP Laptop 14-fq0xxx
                 BIOS: F.52 (type: UEFI)
            Processor: AMD 3020e with Radeon Graphics                  (2 CPUs), ~1.2GHz
               Memory: 4096MB RAM
  Available OS Memory: 3464MB RAM
            Page File: 2855MB used, 4072MB available
          Windows Dir: C:\WINDOWS
      DirectX Version: DirectX 12
  DX Setup Parameters: Not found
     User DPI Setting: 96 DPI (100 percent)
   System DPI Setting: 96 DPI (100 percent)
      DWM DPI Scaling: Disabled
             Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.2.2
DxDiag Version: 10.00.22000.0001 64bit Unicode
