To be more specific, pic below of my old TV i use for zwift. I just did a factory reset on it: no impact. I attached the make of my oldest AppleTV as well, it’s on the newest firmware.
This combo was working 2 days ago before the zwift update.
Ok final update: only my middle aged AppleTV (also A1625) runs the latest version of Zwift on all 3 of my TV’s. My newest AppleTV (A1842) and my oldest AppleTV do not run Zwift anymore since the latest update on neither 3 TV’s…
This is getting ridiculous. If this is going to take a week to get fixed you really should be able to do a rollback on ATV devices to use the older version while we wait for a solution. A large and paid service like Zwift should be able to prioritize an issue like this. Disappointed.
Tried everything same as everyone. Previous user said he downloaded RGT and Zwift then worked. I’ve just done the same while downloading RGT it has suddenly worked.
My sense is the act of downloading anything created a consistent enough Wi-Fi connection that Zwift could work.
For users still not working, it might be worth trying to download any app and whilst it’s downloading, see if you can get Zwift to load. I’d suggest a large app - RGT worked for me, but you could also use something like Facebook.
Certainly share in your disappointment - Another day and still unable to launch the app. I’m sure the team is actively working on a solution and appreciate their efforts; but as a company Zwift has been a real let down with numerous crashes and bugs during promoted events & now I can’t even manage to launch the app.
I’ve downloaded FulGaz and will be checking out the other options…something I’d previously considered, but now have literally no other option if I want to use my trainer.
This sounds like a really edge solution, but it might just work. I had been through the remove/reboot/re-install route as well as the “keep trying to launch” - nothing worked consistently.
I accidentally started to stream Apple Music through my ATV - and Zwift started. So the “have a steady connection” might work. My Wifi connection is pretty solid so no idea why Zwift is having issues.
I need to find a long ethernet cable… or Zwift need to downgrade for a while.
hi all. I’ve also been suffering from this problem since the update (Apple TV HD on WiFi). I’ve been through numerous resets and reinstalls and for no rhyme or reason it’s suddenly worked. one thing I did notice is when it kicked me back to the home screen, I double-clicked on the home button of the apple remote (to open the app switcher) and zwift hadn’t quit at all, it was still open on the blue screen. I simply navigated to it and it loaded into the login screen successfully.
after a little pedal, I quit the app and reopened but it bugged out again. repeated the same step and it worked. so I guess what I’m saying is when it kicks you back to the home screen, open the app switcher and select the zwift window.
never-the-less I’ve ordered an ethernet cable to provide a more steadfast fix til this is officially sorted
FYI I just tried my method above again and it works 100%. Once you get kicked back to the Home Screen, open your app switcher and simply go back to the blue zwift screen. It’ll stay like that for 10 seconds or so then load in. Hope this works for others
Good news, everyone: We’ve found a fix for this issue and will release a patch ASAP. Keep watching this thread for an update when it’s in the Apple App Store.
Thanks again to everyone who took the time to send in their tvOS system logs, and also those who provided important information in this thread.
As a non tech person, what I find frustrating is that zwift do not publicise via Social media that there is a problem and I have to post questions and get signposted here.
Xbox do this on games when they have issues. It would have allowed me to know about this in advance and therefore use an iPad or some other alternative.
I’d love it if they updated https://status.zwift.com/ when major incidents occur, such as a broken release of client software, or all events disappearing.
