I haven’t used Zwift since the spring. When I used it today I could not access the Dashboard page on Zwift Companion - the screen that showed just data like speed, watts, distance etc. There is no longer an option to switch to it. The only screen that showed my ride was the Map screen.
I Googled this and it said Zwift discontinued it. Is that correct?
Am I doing something wrong?
I am able to see the Dashboard on ZCA as of my last ride on Sunday. I am using Android tablets running ZCA version 3.74.0 (2137), which appears to be the latest version
Zwift have discontinued the 25km free for ‘dormant’ subscribers, so if you’re not currently paying a sub, maybe it’s connected to that?
I assume you are using an iPhone, I believe there was an update to that recently and it is working differently now, look for some buttons along the bottom of the screen now, I think that is where the dashboard is located (I don’t use iOS so not 100% sure).
I have had the same issue for a couple of months on iPhone, connecting to Zwift running on macOS. Initially I assumed it was a bug that would get fixed but it doesn’t seem that way now. Map and workout views work fine, and can toggle between them by pressing the icon on the bottom of the screen.
Has it been removed? The map screen is useless to me and much rather a full screen view of stats..
