Zwift-Click - Screws bad quality
At my second battery-change at the zwift-click two screws broke. So I tried to turn out the rest of the screws an they broke again and it was not possible, to get out the rest without damaging the click. The result is, i had to order an new Zwift-Cog. I think, the quality of this screws is really bad.
Has anybody else had this problem?
Did you contact support and ask if they’ll replace it?
Nein, die Garantie Frist ist leider schon abgelaufen. Habe einen neuen Zwift-Cog bestellt..
Is this the heads of the screws rounding out?
Do you have photos? It might be possible to still remove them if we can see what has happened: and replace them with screws from a different supplier.
I had a problem with a screw holding in place a Bluetooth antenna in a 2010 Mac Pro. In Apple typical fashion the screw was tightened to EXTREME level. The recommended jewellers screwdriver wouldn’t shift it and just ended up rounding the head. I had to use some pliers to loosen it.
I am experiencing the same issue. I have already tried three different precision screwdrivers, but none of them were able to loosen the screws. If I continue trying, I may end up stripping the screw heads, which would likely prevent me from replacing the batteries.
Does anyone have an idea on how to safely loosen these screws?
Do we know whether the screws are JIS vs Phillips standard? A Phillips in a JIS can be harder to remove JIS screws without stripping.
Zwift support article says Phillips.
  1. Remove the Zwift Click from your handlebar by unhooking the rubber attachment bands.
  2. Using a small Phillips-head (crosshead) screwdriver, unscrew the four screws from the back cover of the Zwift Click.
  3. Remove the CR2032 battery from the Zwift Click.
  4. Insert the new battery into the back cover with the + side down.
Evidently most newer ‘phillips’ screwdrivers are often built to also meet jis standards. I guess this is to say that I’d recommend if you’re using an old phillips screwdriver, it can’t hurt to get a new set and also ensure it meets jis standards. JIS works better and works with phillips screws.
I have used an 2K PH 0 x 60 mm but it doesnt work with this.
My 4th battery change of my click today, I replaced the original screws with M2X6mm torx screws.
I agree, these tiny screws are really bad, It is really hard to replace the battery without stripping them.
I also liked the Zwift Play Controllers much better than these new Clicks. :face_with_diagonal_mouth:
