Is there a chart that we can use to verify that we are getting the right power readings.
for example Cadence and gear should equal a certain Wattage on the Travel Trac Fluid trainer? I have a travel trac.
Im also having problems with getting “beliveable” reading from this trainer…any insight?
@mark do you feel your is off also? how old is you travel trac. from what i understand they support the newer ones but even my 2012 version seems to be quite off but the curve i have from trainerroad seems to be spot on.
