Performance Travel Trac 2000 Fluid trainer
so I’m using an old Performance Travel Trac 2000 fluid trainer. I tried using the Performance Travel Trac Comp Fluid and I got mad wattage (200+ watt going really easy)… Using the unlisted option I think give me a more realistic virtual power (similar to what Strava estimate on my real ride). I wonder if anyone got recommendation on what trainer have equivalent power curve? Or should I stick with using the Travel Trac Comp Fluid?
I have never use power meter, so my current reference is the estimate power generated from Strava.
Hi Lawrence,
You should definitely choose “not listed” for now. We highly recommend using supported equipment in order to get the full experience.
Thank you and Ride On!
