The race is on zwiftpower ZwiftPower - Login
But i’m going to assume as you are new to zwift you had not setup your zwiftpower data sharing from your zwift profile so you won’t appear in results there.
if you have done not already make sure you allow data sharing from zwift for you to appear on zp results.
You are correct, I just learned about zwiftpower today, so I wasn’t logged in at Zwiftpower at the time of the race.
No way to get old races in ?
I don’t have the consent form mentioned in the guide you linked to. Do I dare to presume, that it is because I all ready did what I should?
Zwiftpower is showing my total km and height, but nothing else.
consent option should be here The at Home Cycling & Running Virtual Training App
and no I’m afraid not there is no way to import past results
Did a new race today and it synced fine. So the issue properly was as you stated, it dosn’t sync past results.
Thanks.
