Hi All
When i end a ride i save it the image’s get up loaded. After that it put’s me back at the login screen tap name to sign in then have to pair everything back up for another ride.
Using samsung galaxy A8 tablet running the latest update. Other then that no provlem’s so far.
That’s how it works on Android. It’s not a bug or fault. Most people don’t do multiple activities in one session unless they are badge hunting on shorter courses perhaps.
Cheer’s Stuart for the info i did’nt know that’s how it worked in android.
i did one ride at 32ish miles then another at 7ish miles. Not badge hunting just exploring routes i have not done yet been zwifting since feb 2nd this year.
Many Thank’s
Andrew
Keep ticking them off.
You’ll learn more and more as you go.
Here a link that’s got loads of useful stuff & of course if you’ve any questions we’re all here to help.
I’m another user who does not like this behaviour. I recently started using the Android Zwift App having used a PC for Zwift for many years. Using a tablet also means that devices have to be paired via Bluetooth (rather than Ant+) which can mean the usual problems with getting Bluetooth devices to pair straight away. This means that after finishing one ride I usually have to mess around for several minutes re-pairing devices before I can start another ride, wasting valuable riding time! I can see no good reason why after saving a ride I’m booted right out to the ‘select user’ screen. On a PC I go back to the home screen. Please could Zwift Devs consider changing this behaviour on the Android App? It has been pointed out to me that if I enter an event, whilst doing a free ride I should get the ‘Join Event’ option (c. 3.5min before the event starts). Joining the event in this way means not having to repair sensors. However in the past the ‘Join Event’ prompt has been a bit hit & miss, and I’d rather not leave it that late in case I do have to manually join the event, meaning having to take time repairing sensors. I hope this makes sense.
