What’s going on with Jet Black victory?
I just got dropped and it’s not allowing me to get reconnected. Haven’t had a problem with the trainer connection until now. :enraged_face:
I just had to unplug it and plug it back in. That’s real annoying and inexcusable. If it happens to me in a race it’s going out the window.
What firmware version are you on? You can check out the giant thread on it, but there have been issues with wifi connectivity dropping out, but Bluetooth connectivity seems to be solid. The latest firmware seems to have fixed wifi connectivity, but (or maybe a plus for racing?) now seems to be reading 10-20W too high at least for some people.
Hmm. When I went to go see my firmware and check for updates it says I got a failed to get current version. I believe I was on 14 something.
Hi @Kru,
Thank you for bringing this inquiry to our attention! This is Jose from Zwift support. I’m sorry to hear about the disconnections you are experiencing. I checked your recent logs and noticed that your trainer has the latest firmware version, 4.17. However, this firmware version should resolve connectivity issues found in the previous version. Since you mentioned receiving a “failed to get current version” message, it seems this update has not been installed yet.
I also observed multiple disconnections from your trainer’s controllers while you were in-game, likely due to the same issue. I recommend following the article linked here to resolve your connection problems. However, it seems the issue may be stemming directly from your trainer. Ideally, you should reach out to Jet Black support for further assistance. To contact JetBlack Cycling support, you can email them at: support@jetblackcycling.com or supportUSA@jetblackcycling.com
I hope this information is helpful! If you have any more questions, feel free to ask.
And 4.21 firmware is constantly dropping out after about 20 minutes or so on wi-fi, very annoying. I would like to go back to 4.17 but I can’t find a way to do that :frowning:
G
And again today after the trainer being on for about 23 minutes, please fix ASAP or give us a way to go back firmware revisions thanks.
G
This forum isn’t a way to communicate with Jetblack, and they’re the only ones who can help with rolling back firmware.
I hit them up on Reddit.
G
If you look at larger Jet Black discussion on Feb 5th there is a post on how to roll back the firmware using DFU. Can just use search function keyword DFU.
Unfortunately this only goes back to 4.13 :frowning:
G
