Hi, Is it possible to ride my Wattbike Atom on Zwift without using the Wattbike Hub app? I tried doing a workout on Zwift but it would never reach the required power and I’d eventually just spin out when power increased. The two were only compatible when connect the Wattbike app and then zwift, but I don’t want to use the Wattbike app AND Zwift
You shouldn’t try to use both at once. That’s likely to end up with both apps trying to take control.
If you want to use Zwift, I recommend force closing the Wattbike hub app, powering everything down, and then fire everything up and connecting to Zwift.
