Water effects in places have lost some of their blue hue and if the sun hits it just right looks like a grey mist (1.41)
Yeah, I got this too
I got these again but in Watopia today - water was grey - think it might be the same as the over exposure issue in the tunnel that has been around for a while
edit - sorry should have said was in the desert bit that has a slight uphill and water
“Slight uphill”!?!
That’s a terrible slur on the mighty Col du Tempus!
+1 seeing grey water bodies (Windows).
Thanks for the reports everyone. So far - folks reporting this on Windows and macOS.
Anybody seeing this on iOS / AppleTV / Android?
I can confirm Android is also affected.
Water is normal in Watopia for me today on PC.
Not all water surfaces are affected. In Watopia I didn’t notice any grey water. In Makuri, the country lakes are grey but the ocean is normal.
Does it really matter
Based on that last photo I was struggling to see the issue. I’ve often seen water look just like that though it’s normally under a grey sky ![]()
Yeah just looks like some hazy sunshine reflecting off of it
Yeah, loving the new feature, just like IRL when the sky is grey. Thanks Zwift, you are awesome!
Can’t tell if you’re being sarcastic or not?
That theory does fall.apart when the river in France, where it is always sunny, is affected as is the water in the desert.
is this grey water going to effect your results if you go past it while doing a ramp test, is it going to effect your Cda while drafting a robopacer that you’ve managed to join up with after having a coffee stop half an hour into a group ride, will it cause you to miss out on a PB on a nearby segment, I would guess the answer to all of the above is … NO
